shh-the robot is sleeping
Help finding “hot air tube/hose”
Looking to replace this hose:
The Hot Air Tube/Hose from our host does not appear to be the same.
I’m looking to keep these details as original as possible. Is there another source for an authentic replacement?
Is it the same hose but just looks different on Pelican Parts?
TIA.
'88 911 Coupe, 69k miles
Old 03-18-2018, 11:58 AM
steely's Avatar
Not OEM but if interested in an alternative try searching here for CEET or SCEET ducts from Aircraft Spruce.
It's a Hi-temp vent duct used in aviation.
example
how much ducting for a 3.2 heat backdate?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-18-2018, 03:45 PM
Look at the Classic Retrofit Electrocooler instructions. In the build of materials they list the right foil type tubing. I think they list it as "Webasto aluminium/paper hose."
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-19-2018, 07:43 AM
