Location: Vilnius Lithuania (it's in Europe and it's not Russia)
windscreen and headlights wash question
Hi, maybe someone could post some pictures how windscreen and and headlights washing system should be connected. It took a while since I have disassembled my car, so now can't remember how to make it work. Strange thing for me is that, why do I need 3 water pumps to do 2 functions?
Flat Six
What year?
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
1986
Flat Six
From Porsche parts list.
Windscreen washer system: ![]() Headlight washer system: ![]() You can download your own copy here: http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_84_86_KATALOG.pdf
thanks, but this still does not cover the third pump, that is under washfluid tank that is under the bonnet. and where should go hose indicated with an arrow?
Having stripped my washer system down and rebuilt it some months ago, I think from memory that the hose with tba arrow is just an air vent, ie goes to atmosphere. On my 86 euro the hose went through the inner wing behind the battery and is just for overflow or breathing. When I tried to empty my reservoir it was full of nasty smelling "jelly" probably weighed 3 or 4 Kgs. Had to rinse it thoroughly and eventually put it in the dish washer for a final clean, swimbo was unaware. HTH
'85 Carrera 3.2 Coupe |
and talking about pump [17]. It can collect water from tank only through connector [32] using hose [2g] and there is a t type connection, so this means that it will be taking fluid from washers and reservoir and will be blowing it back to reservoir through hose [2b]? please correct me if I am missing something...
Flat Six
Ornas: Sounds like your car might have the optional Intensive Washer System, with a second reservoir (and third pump) inside the front trunk near the brake booster/master cylinder, yes?
If so, perhaps this diagram will help you:
intense washer is correct
Noticed this on new to me '86 carrera. Not sure if just hits the headlights or the windscreen as well. Oh those mad Germans...
Flat Six
Here are a couple of threads that describe more (and show pictures): Intensive washer reservoir Need any info for high-intensity washer conversion Hope this helps.
Thanks for this -- I've noticed in the past that when my washer fluid is running low, my headlight washers will stop working -- now I see why
