-   -   993 55 pin DME wires color chart- help!! (http://forums.pelicanparts.com/porsche-911-technical-forum/660497-993-55-pin-dme-wires-color-chart-help.html)
mmasse 02-23-2012 07:21 PM
I am in the process of installing a Supercharger into my 3.6 conversion car. Engine is a '97 993 Euro Varioram with a 55 pin DME connector. I need to do the wiring of the SC piggyback computer. I have the DME pin-out which allows me to identify into which pin number to connect the wires from the piggyback unit. The problem is that it is impossible to identify which color wire corresponds to which pin number on the DME.
Does anybody has a chart which tells which color of wire relate to a specific pin on the DME connector?
mmasse 02-24-2012 05:41 AM
what I need is the color code of wires # 7(MAF), 37(12V), 48 (Crank -), 49 (Crank+) and 53 (TPS)
Anyone PLEASE!!
http://forums.pelicanparts.com/uploa...1330090864.jpg
Bill Verburg 02-24-2012 06:20 AM
Anyone PLEASE!!
first the above connector is for a US non vram and is not 100% correct for a RoW '96-98 vram motor
on the '96 - 98 RoW Motronic 2.10 vram motors
pin 7 MAF is 0.5 Bl/Gn
pin 37 MFI+Di relay term 87 is 1.5 Re/Wt
pin 48 ESS connection B 0.5 Br
pin 49 ESS connection A 0.5 Wt
pin 53 TVS 0.5 Wt/Gn
mmasse 02-24-2012 06:23 AM
Thanks Bill!!!!
redturbo911 02-24-2012 09:44 AM
I was going to tell you contact bill v for his wealth of info but he beat me to it. Good luck.
