-   -   How bad is it? newbie question (http://forums.pelicanparts.com/porsche-911-technical-forum/660773-how-bad-newbie-question.html)
brakedw 02-25-2012 05:15 AM
Just found a little problem with my 89 cab. How bad is this? Is it safe to drive?http://forums.pelicanparts.com/uploa...1330175666.jpg
crashmy911 02-25-2012 05:19 AM
Get it fixed. Use wevo mounts.
Oh Haha 02-25-2012 05:20 AM
WEVO has new, stronger mounts that can be welded in.
You can drive it without risking your safety but I would not drive it hard and get it repaired ASAP so as to not cause any more damage.
You COULD remove the sway bar altogether until you get the mount repaired. Your handling will be compromised but it will be driveable.
It seems Buckley has introduced a mount as well.http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSshk_pg9.htm
tobluforu 02-25-2012 05:20 AM
If that is your swaybar mount then yes it is ok, but I would get under and remove it. Now, take it easy around turns because the car wil not handle the way you are use to. You will need new ones, of course, so get wevo's.
brakedw 02-25-2012 06:42 AM
thanks
thanks for the advice! I'll get right on it. it looks like the drivers side has already been worked onhttp://forums.pelicanparts.com/uploa...1330180914.jpg
brakedw 02-25-2012 02:12 PM
my other mount looks ok should i leave it alone or replace both at the same time?
newms 02-25-2012 02:44 PM
Your car is safe to drive although it is a good idea to remove the rear bar asap. You can drive it until the mount is repaired though as stated the car will not handle great. Specifically the car will undrsteer and will feel like it doesn't want to turn. Several options for repair/replace but should be done by a shop as you need welding done.
hcoles 02-25-2012 04:49 PM
this is common failure, try to find a shop that will do a nice job e.g. rust proofing/painting of the final weldment, maybe someone can mention a good local shop with P-car experience
Cotton175 02-25-2012 05:02 PM
http://www.gouptoday.info/avatar1.jpgUse wevo mounts.
pegasus9 02-25-2012 09:15 PM
I'd replace the sway bar rubber bushings while you're at it.
That side looks fine. Up to you though, your call.
stlrj 02-25-2012 11:08 PM
I was very satisfied with the job done by a muffler shop. These guys know how to prep, weld and rust proof since that's what they do and it's all done without the Porsche price tag.
NeedSpace 02-26-2012 06:11 AM
Is it me or does the bushing on the repaired side look a little worn? Shouldn't that gap not be there? Perhaps it is simply due to the other side not being properly attached, but I would replace that bushing while I was at it.
Tigerrat 02-26-2012 08:15 AM
I've done both on my '88. Did not use the Wevo's but I think a newer more robust one. I'm still new to the area so would be interested in knowing who you get to do the work. Thanks, Ken
Eagledriver 02-26-2012 10:54 AM
It looks like the mount nuts have just stripped out. You might be able to use bigger bolts and a tap to repair.
-Andy
brakedw 02-27-2012 10:36 AM
so here is the update... I'm a failure..... It sounded like simple process, jack the car up (check), tires off (check), pb blast soak the bolts (check), remove bolts (fail), i tried socket wrench, breaker bar, impact hammer, resoak, drink beer, repeat process, no go.
I really wanted to get it off so I could know if i neede new bushings as well, oh well,
any bright ideas?
Porchcar guy 02-27-2012 12:43 PM
Heat with a torch and more PB Blaster ?
CCM911 02-27-2012 01:02 PM
I just went through the same thing this weekend on my 84 Targa. I could not get off the one bolt where the sway bar attaches to the drop link. If this is your problem, you'll need two 19mm wrenches. And don't be afraid to push on one with your foot. Sounds strange, but we got mine loosened in that manner.
Tigerrat 02-27-2012 01:11 PM
More PBB and a cheater pipe on that breaker bar. Ken
NeedSpace 02-27-2012 03:39 PM
Had a similar problem myself. PB Blaster overnight, then heat the metal where it screws in, not the bolt itself. I took a 8 foot pipe to extend the wrench. Good luck!
brakedw 02-28-2012 09:58 AM
restored hope
I'm going to give it another go. I jacked it back up after driving it a little. back to the overnight parts soak and Ill be bringing a torch and a long bar for good measure. we will see how it goes tonight, I'm just going to have to laugh if it all catches fire from the PB blast:)
CaptainCalf 02-28-2012 10:33 AM
Stop!!! You forgot the beer to drink & put out the fire:)
gabenheimer 02-28-2012 10:54 PM
Just keep using the PB blaster. Try some heat if necessary. Several years ago a posted a thread about replacing the mounts on my '86 targa.
jrolstin 02-29-2012 12:58 AM
At first glance I thought that was a torsion bar mount... That happenned to me not long ago...
brakedw 03-01-2012 07:33 PM
success
finally a little more pb blast a longer breaker bar. I need to go back to the gym or make more money for power tools:) I am really suprised how flimsy these sway bar mounts are. now beer time
dicklague 03-01-2012 07:48 PM
Nothing like an air or electric 1/2" impact wrench to get those things off. Good investment.
I would just have the other side welded with a new fabbed bracket. I made my own and welded it in place. The repaired side looks really good. Save the $$ on the Wevos!!
Dublinoh 03-04-2012 08:53 AM
Looks like the nuts are still on to me, and the mounting bracket has failed. If I am right you need to have the old bracket removed (grind it off) and weld on a new one. Wevo makes a very strong replacement and I think they are sold by our host. Your car will handle like ***** until this is fixed FYI.
