Economical engine choice
Got a 74 911 roller for little $ and am flirting with engine ideas of how to power it on the cheap. Type iv? 2.2? Suggestions.
minivan - all stock |
RETIRED
No such thing as a cheap Type IV anymore....watch the ads for something...they pop up every once in awhile.
Or you can do a Chevy V8.....%^b
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Cheap, reliable, fast. Pick two...you can't have all three.
Never said fast, so just cheap and reliable....I'll settle for cheap. I'll treat it like a vw beetle driver.
$2000-3500 budget cheap
sell the roller. save the money. buy a car when you can afford to maintain it.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
And then, of course, there's always MotorMeister:
Never said didn't have the money. Just want this to be a cheap project.
At least entertain the idea rather than shoot it down.
As a teenager, we used to drive these "humble" cars. Things changed after college. I can now afford just about any car I want. However, i'm still intrigued by the rust bucket and humble porche that has one window covered with duct tape and plastic.
there are planty of used engines at 3k... but most will be worn out. what i would do is plan on a top end and some misc bits on top of the 3k. maybe 5k? still cheap compared to a full on rebuild...
300hp 1800lbs is the goal
JDM subaru ej20 with tranny..... convert awd to 2wd, then reverse r&p from Australia... good for some weight reduction too.... subaru tranny is less weight then a 915
~$3000 for about 280hp
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Probably a better choice at his price point.
Prefer air-cooled, even if I have to put a vw int it.
RETIRED
Scooby conversions even with a hair dryer have been known to run well with radiators in the engine bays of 914s....also have seen a 911 'vert with a rad where the AC unit used to hang.
Just thinking out loud... probably cheaper to do a 3.0 than a vw because of the fabrication factor in the VW. you could spend 3k on a 3.0 or you could spend 3k making a a vw work. seems like the cheapest air cooled choice for be a 2.7, but if you want some reliability a 3.0, then id say type 4 after that...
