wjfk32's Avatar
Old 915-Clutch Disc/Other Pics
Greetings:
82-911-SC-Targa-Some Pics of my clutch disc-shot--and pedal shaft-shot--and some pics of my engine..
Went by the shop on the weekend to see the progress--Didn't think the engine was going to be in so fast.. Replaced the rocker shafts, new valve cover gaskets and a few hoses/oil leaks..
My wrench- has to do a few adjustments to the intercooler-7th injector placement , and all is done....
I installed a KEP-STAGE 2- 915..(ALUM-PP,Pilot bearing-Kep organic disc-.New clutch wire,bushings..etc....1st impression as for feel..... I immed. thought for the worse...
But i was wrong.....It was very smooth and definetly lighter than my orignal set-up...Pleasantly surprised....Glad I went with a stage 2.
Walt
Old 02-27-2012, 08:50 AM
Mo money = mo parts
If by any chance you or your wrench still has the old clutch disc, I would like to buy it. I have some transmission work planned and need an old disc to make a tool that I will need. Thanks.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-27-2012, 09:50 AM
wjfk32's Avatar
Disc
Sure..
Have the pressure plate and cable wire also if interested..
Walt
Old 02-27-2012, 11:30 AM
