-   -   Remind me. Valve adjust ok with spark plugs put? (http://forums.pelicanparts.com/porsche-911-technical-forum/661890-remind-me-valve-adjust-ok-spark-plugs-put.html)
vash 02-29-2012 07:30 AM
About to put in an order. Tune up time. I want to change plugs. I remember a prob with carbon buildup messing with the process. Remind me?
Danny_Ocean 02-29-2012 07:33 AM
You can adjust the valves with the spark-plugs "out" if that's what you're asking. Carbon build-up on the valves themselves will affect the settings.
hcoles 02-29-2012 07:35 AM
adjust valves first, then remove/replace plugs
ivangene 02-29-2012 07:36 AM
the thought is that removing the plugs and rotaing the motor increases the risk of a piece of crap falling into the valve seat and sticking - I advise plugs in for adjustment...then change plugs one at a time
others might have another take on it but I spend two days scared sheetless with an 80% leakdown on one cylider due to a chunk o crap after a compression test with all plugs out
