tazzieman's Avatar
Q re SC coil support bracket
Why is it mounted this way , when the coil will bolt directly to the fan housing?
What else would bolt to the threads on the right?
Might it be some way of reducing heat/vibration transfer???
I've removed mine , and maybe in the past there was an airpump or something attached?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 02-29-2012, 05:36 PM
Gary H 1978 911 SC
Mine is like that so the AC condenser fan will close and not rub on the coil.
Old 02-29-2012, 06:03 PM
jmod's Avatar
The air pump support/stabilizer bracket attaches to the top bolt on the fan housing closest to the camera. There is a small vibration damper close to the bolt which needs some room to clear the coil.
Jim M.
79 911SC
Old 03-06-2012, 11:53 AM
pete3799's Avatar
Same on mine.
Pete
79 911SC RoW
Old 03-06-2012, 12:49 PM
