-   -   915 Question - What's this sensor? (http://forums.pelicanparts.com/porsche-911-technical-forum/662375-915-question-whats-sensor.html)
jrolstin 03-02-2012 05:10 AM
Hey guys, I had a question... what is the sensor in this picture, and can I order a new one from our host?
http://forums.pelicanparts.com/uploa...1330693787.jpg
Regards,
Jonathon
john walker's workshop 03-02-2012 05:23 AM
speedo.
jrolstin 03-02-2012 05:30 AM
Is it possible to buy a new one? It looks all melted kind of...
schumicat 03-02-2012 05:34 AM
yes. but yours may just be dirty. it looks unfinished on that side even new.
Walt Fricke 03-02-2012 05:00 PM
If your speedometer was working, don't bother getting a new one.
If you cut the wire to pull the transmission, you can just reconnect the two wires. Doesn't matter which wire connects to which.
The sender is a reed switch, which closes each time one of the eight magnets inside the transmission passes by it. Closing the reed switch grounds a circuit. You could check its function easily enough with an ohmeter and a magnet.
Otherwise, when you clean the oil off of the tranny, it should clean the wire enough that it doesn't look decrepit.
