Paris Mtn, SC
1972 valves - Non-intrusive?
Are the valves in a 72 engine non-intrusive? in other words, if the cam chain breaks and the motor still runs, are the valves getting pounded by the pistons? Please tell me no....grin
No - intrusive...just like any other MY.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Broken cam chain = expensive.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
i think the phrase you are looking for is " interference engine" and yes it is .. if your tensioners are making a noise you might get away with it .. but if the chain broke its tear down time .. and parts for that engine ? .. wow..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
The '72 is "special" with it's forward mounted oil tank with the filler on the right rear quarter...the only year to have that feature. Also, the '72 "S" came standard with a front mounted radiator oil cooler...that became an option in '73.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Paris Mtn, SC
I plan on removing the sheet metal this weekend, pull the cover and see what I have going on. Is there any chance the valves and pistons are not beat up? I'm hoping the pin came loose but if the valves are slapped around, I'll pull engine and build it fresh.... Thoughts? The car will crank and idle to my amazement.....
Are you sure it's not a loose rocker? Pull the valve covers and have a look.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Paris Mtn, SC
Yea, Cam is not turning at all on the passenger side.
Do you mean that the cam is not turning with the engine running, or is it stuck?
Do you have the chain covers off? Can you turn the cam with a wrench by hand? Pull the plugs and try. I doubt that there is no damage but anything is possible, if it turns freely and all the rockers are not cracked or broken, no strange noises then you might be OK. If so then the next step is a compression test that should tell you if your rings and valves are ok.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 03-28-2013 at 11:29 AM.. |
Since you say it will start and idle, it is most likely running on just 3 since the right bank cam is not turning.
You may have minimal damage, but until you look at the heads, pistons and valves you will not know the extent. The risk is that you may be able to get it running again without opening it up only to have a valve head break off due to slight damage from light contact. Knowledge is peace of mind. |
Yes, there is a chance no internal damage. I had the chain slip, break 3 rocker arms, and do no internal damage. Just fixed the chain & replaced the rocker arms. You could try a leak down to determine damage.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
Paris Mtn, SC
Pulled the valve covers and that where I discovered the cam is not turning at all. Rockers appear to be intact but will do a deep dive on them to verify. Did not try to manually turn. I will pull the cam chain covers this weekend to see what going on. Pending resolution, I'll fix, run compression and leak down tests while keeping fingers crossed. Then decision time....... My thanks for all the positive feedback.
Paris Mtn, SC
Update: Pulled Cam cover. Pics to follow. Good news is: Chain is intact. Bolt was loose and only one round to take it off. Washer behind bolt was warped. Found metal in bottom, pic to follow. Not sure where it came from. Rotated engine and used mirror to check all teeth. Seem to be fine. My first thought was teeth from sprockets. Pic posted of the dowel that seems to be sheared off. I need the experts to weigh in here. Cam is free and turning manually.
Also, pic of the cam tensioner, Is this the updated one? Thinking, if the metal parts are from the pin, I can re-time, run compression and leak down checks and just maybe be ok. I'll post the pics in high def so maybe someone can zoom in to see that the metal pieces are from. (Pin or sprockets) My thanks, Wes ![]() ![]()
Paris Mtn, SC
Pic of cam sprocket.
Senior Advisor
see if you can get a picture of the cam end of the chain. oh, ok thanks. might be the sprocket on the cam that sheared off
08 Cayenne Turbo |
Those look like pieces of sprocket. Check the sprocket on the cam & tensioner wheel & look for missing teeth. If they are all there, then the intermediate shaft sprockets are broken. That will entail a complete teardown. I have been working on these cars since 1977 & have never seen a 911 engine jump time & do no damage. Never.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Senior Advisor
16 or so teeth on that inner cam sprocket so many more parts floating around the engine. You know what that means, sorry
08 Cayenne Turbo |
If there are no oil lines to the tensioners then they are the old pressure fed kind. The one in the pic looks collapsed but it is really hard to tell from that angle.
Your best bet is a complete tear down and rebuild, anything else is a gamble. Financially it might be wise to just find a healthy lower mileage or rebuilt engine 3.0-3.6. Or you might be able to get some decent mileage from a your 1.2 liter. ![]()
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 03-29-2013 at 08:26 PM.. |
