Picture of 1973 MFI rear relay panel please?
Hi,
I tried searching but I am not sure the pics I found actually is from a 1973 car.
Anyway, my car came without rear relay panel (the one in the engine bay), and I have 3 different ones in my parts stack to chose from. So, could someone please post a pocture of what it should look like?
Also, I believe the car should have the MFI fuel filter with the cold start enrichment valve on top, right?
The car is a 1973 911 T MFI Targa.
Any help would be very appreciated!
Regards,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 03-04-2012, 12:03 PM
HarryD's Avatar
Johan:
This looks to be a 1971 but should be really close.
Originally Posted by derek murray View Post
The RPM Transducer (aka Speed Switch) is located on the electrical console in the engine compartment. It is #5 on the photo below.
(C) 1971 Dr. Ing. h.c. F. Porsche A.G.
...and for the archive, here's the complete console layout
1 - Console
2 - Relay switch for single stage rear window defroster (not used with two-stage window defroster)
3 - RPM Sensor
4 - Relay switch for start enrichment (not used in carburetor engines)
5 - RPM transducer (not used in carburetor engines except 911T USA version)
6 - Control Relay for two-stage rear window defroster (not used with single stage defroster)
7 - Radio noise supression
8 - Regulator
9 - Ignition trigger unit
10 - Fuse box III
Originally Posted by jsoderbe View Post
Hi,
Regards,
Johan
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-04-2012, 01:39 PM
1973 s
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-04-2012, 02:01 PM
Thanks guys! Harry, that is the one I found but I wasnt sure if was the same on a 1973. Combined with RSTarga's picture I have what I need to get it going. Perfect
Regards,
Johan
Old 03-04-2012, 10:13 PM
