Porsche Enthusiast
rsnodgrass's Avatar
ECE silver door stickers available?
Does anyone reproduce the silver ECE tags for 1976 (and beyond) Porsche that go in the door jam? I am debating keeping the sticker when painting the car, or removing when repainted and using a reproduction if available. Mine is currently covered up by another sticker.
74 Carrera 2.7 | 75 Turbo 3.0 | 97 Boxster | 12 Cayenne S
GONE >> 04 GT3 | 75 Carrera 2.7 MFI | 76 Carrera 2.7 MFI | 77 Turbo Carrera 3.0 | 86 Carrera 3.2
Old 02-24-2012, 08:18 PM
80-911SC's Avatar
that's one I have not seen ..
but I know that you can take a high resolution picture and then get it printed out .. if you take the picture on the same flat plane that the original is (when you view it the corners should be 90 degrees) you should be able to crop it out right .. I would recommend a sign shop that has good quality printers so they can do one that is water proof and resistant to weather .. even though the door jamb is protected it would suck if it ran on you in 6 months ....
Same process they use for vinyl graphics .. in fact may be check with Joe Bob here he may be able to or send you to some one who can ...... Joe's graphics are famous here ... Hit him with a PM .. He is another that's almost always here ......
Old 02-24-2012, 10:27 PM
80-911SC's Avatar
Joe says there may be legal issues with sticker repops so he would not be able to help here ...
I have seen guys make stickers on an inkjet printer .. this may be a do it your self job or check around ....
Old 02-24-2012, 11:23 PM
Cover it while repainting it will be very difficult to ever replace
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-25-2012, 07:39 AM
Porsche Enthusiast
rsnodgrass's Avatar
Sounds like covering and trying to blend the paint is the only option. Plus side this preserves the original DOT import sticker as well, though that is less of a concern for me.
Old 02-25-2012, 11:07 PM
? Silver Sticker
Thanks, but what is the translation?
Old 10-05-2015, 07:03 AM
have a look here
Products | Car-Bone.pl
http://www.carrera-32.com
Old 10-05-2015, 07:51 AM
Hi-Carbone in the link above made a set for my sc a couple of months ago from photos and given dimensions.They were the first set of these that they had made and turned out great.
Old 10-05-2015, 01:43 PM
