Anyone run this lithium battery?
Lithium battery replacement for automobiles and motorcycles
They sale a lithium battery that will hold up in my 911 turbo for $395 so that sparked my attention, but not sure......
I am looking for feedback if anyone is familiar with them
Old 03-06-2012, 07:00 PM
sc_rufctr's Avatar
I don't know anything about them but they look great. Bit Pricey but damn they're light.
Peter
Old 03-06-2012, 10:24 PM
Just remember that LiI batteries require additional cooling and very closely controlled charging to prevent excess temperatures.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-06-2012, 11:53 PM
BMWDavid's Avatar
These are lithium iron not lithium ion. Lithium iron batteries do not have the issues that lithium ion batteries have.
Lot of activity in the motorcycle field with LiFe batteries because they are so light and small.
'89 3.2 Carrera Coupe-Silver Anniversary-sold
'06 GTI/DSG
Old 03-07-2012, 01:39 AM
heiliges blechle!
I have an 8 cell LiFePO4 in one of my bikes for 2+ years now and have some input. They work great when they are working right. If you let them run down, they will get out of balance, some cells charged higher than others, and the weakest cell prevents the others in series from working. When you try to charge it back up it will not fix the problem. Some manufacturers have balance connectors on the battery & special chargers that can charge each cell individually and that is a good thing. Other manufacturers do not and they do not warranty the battery if it gets run down. On my battery I am able to access the individual cells and can charge them each separately with a 3.65V 10A charger. I was able to restore it to service after it got unbalanced and would not start my bike any longer. I would look for a battery that gives you the factory option to connect to a balance charger or that gives you access to the individual cells.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 03-07-2012, 08:13 AM
lithium battery
like this ?
this is a 16V racing battery
If charger puts out 14V, thats ok for 12V battery
Old 03-07-2012, 09:48 AM
aftermath's Avatar
I ran one similar in my ls1 track car, it cooked pretty quick and was a bad choice for me. I have a friend who has one in a bmw daily driver with no issues.
theamsoilguy@hotmail.com
Old 03-07-2012, 10:15 AM
The maker of the batteries in the link in the OP's first post offers an option called BMS ($200 extra for auto size battery). BMS (battery management system)is some type of voltage monitoring circuit that prevents a voltage drain and imbalance, which can lead to the type problem that you had.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 03-07-2012, 11:51 AM
ERH ERH is offline
I have been using this in the Caterham, 2.4lt 10.8 compression, with no problems so far (6 months).
EVO 2 , 3 lbs.
Ed
Old 03-07-2012, 01:46 PM
Ed what do you have the battery in?
Old 03-07-2012, 04:22 PM
French member
Aurel's Avatar
Just to clarify things, lithium iron is lithium ion.
Lithium ion means a battery that uses a lithium intercalation anode (graphite in both cases), rather than metallic lithium. But it is true that the "lithium iron"cathode, which is LiFePO4, is safer than LiCoO2 found in most lithium ion cells. It is safer because the voltage is lower, and there is much less exothermic reaction in case of thermal runaway.
Aurelien
'78 SC Targa, DC15 cams, backdated heat and exhaust, AC delete, Turbo tie rods
New rings on Alusils...I did it!
Hear my rebuilt motor! Dyno
Old 03-07-2012, 07:56 PM
ERH ERH is offline
Caterham (Lotus 7)
Old 03-08-2012, 02:20 AM
sc_rufctr's Avatar
Originally Posted by liteweight View Post
like this ?
That looks great but I'm concerned about the copper strips the terminals are bolted to.
They look a bit thin for the current that will be going through them.
Am I wrong in thinking that?
Peter
Old 03-08-2012, 04:16 AM
French member
Aurel's Avatar
Copper is one of the most conductive metals. Lead is only 7% the conductivity of copper, so by using copper, much thinner terminals can be used. Of course copper cannot be used in lead acid batteries because it would turn into copper sulfate right away.
Aurelien
Old 03-08-2012, 05:27 AM
