ssi muffler?
i saw this on the aase site.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 03-10-2012, 03:44 PM
yes. That looks like a Dansk 2in/1out sport muffler. For SSI's, you want a muffler with 2 inlets.
Old 03-11-2012, 04:18 PM
ssis and dansk
I'm looking at that same set up (SSIs and the Dansk 2-1)
Any members here gone that route, and would they do it again or go in another direction?
worth the coin?
How does it sound?
Can you DIY the install?
Thnx,
Old 03-11-2012, 04:47 PM
i dont think thats a dansk. it kinda looks like a monty. i heard that ssi was gonna make a muffler
Jason
81 SC
97 328is
Old 03-11-2012, 05:05 PM
monty
try searching M&K as well
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-11-2012, 06:44 PM
Formerly known as Syzygy
Canada Kev's Avatar
EDIT: Whoops, never mind. Brain fart in progress...
Kevin
Old 03-11-2012, 07:29 PM
I knew what you meant no worries
Ben
89 944,85.5 944
914-6werkshop.com
Old 03-11-2012, 08:12 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
Hand Made
Nice piece. Welding bead looks like "a hand held" weld. Nothing like the welds on my SSI. Polishing probably from a flapper wheel in the shop. Prototype? Marketing sample? Custom 2 in; 1 out?
Old 03-11-2012, 08:13 PM
Now in 993 land ...
aigel's Avatar
worth the coin?
How does it sound?
Thnx,
I had the SSI with a Dansk sport single outlet (with a big pipe)
Worth the coin is always relative. Sure, if you have enough coin, it is worth it!
Sounds awesome - real raspy and throaty and just screams at high rpm. Definitely still streetable.
DIY the install is no big job. The oil lines need changing, and the old exhaust may not come off easily, those are the only two things that may make it complicated.
George
81 SC (sold)
Old 03-11-2012, 08:55 PM
the reason i mentioned ssi is cause its listed as such on their site. odd
Jason
81 SC
97 328is
Old 03-11-2012, 10:49 PM
George
I'll echo aigel's comments. I love my SSI's and Dansk 2in/1out. I don't regret installing that combo for a second. The install is definitely diy-able. Do your home work before attempting by reading everything you can on this site. You'll have to heat the heck out of your hardware to get it to work loose without snapping an exhaust stud. But it's an amazing upgrade for a 911.
Now that I look closer at that muffler, I thought it was a Dansk due to the curved sides, but now that I look closer at the welds at the inlets, it looks more like an M&K. But M&K's have flat sides, so it's not an M&K, so maybe it is a prototype SSI muffler.
Old 03-12-2012, 04:54 AM
