Hi there every happy owner of the funniest car ever built!
I do, howevr, have a minor problem. Does anyone know if it is possible to replave the oli pressure switch of a 911 SC -83 while engine still in right position in the car? Do you have to remove the oil tubes and the pressure valve on the righthandside? // Anders Jihmanner ------------------ The Edge |
Hey; another Viking on the board!
I've seen threads on this subject before on this board - make a search on the subject. You should defenitely not have to drop the engine to change the oil pressure sender, but I suppose that various years requires various levels of effort to get to the switch .Hälsningar Bosse ------------------ 1972 911S Targa ************************ My project! |
unbolt the AC compressor and move it aside. remove the top AC mounting plate. now you have room.
Thanks JWW but I have no AC-kompressor!
No power-consumption which does not fedd the wheels! I do think it's less space around the engine in the cars without AC. Isn't it the best to try go go around on the right side? The Edge |
