911 + 129 = JOB
PDACPA's Avatar
Strut Brace on the way...is it DIY?
My strut brace is due in any day, is it something I can install? Appears that you just remove the bolts and bolt on the strut brace. I have not received it yet, so no instructions to read. Just wondering if I should plan on doing it or have my mechanic do it.
1989 911 Carrera Coupe 3.2
2012 BMW 135i M Sport
"It is not how much power you have, it is how much you have left to spare!"
Old 05-18-2002, 10:50 AM
91C2wrencher's Avatar
this is an easy DIY, yes just remove the required nuts from strut mount and install brace. It would be best to have a torque wrench wrench to properly tighten the nuts back down. Don't recall the torque rating for these nuts, but some thing like 15 ft/lb seems to come to mind. Any self rightous DIY'er should have a copy of the "little specification book" available no doubt from PP as a good resource for these bits of info. (torque and such)
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 05-18-2002, 11:15 AM
911 + 129 = JOB
PDACPA's Avatar
I had a feeling that was all it was for the strut brace, but was not sure if loosening the bolts would makes something come apart while they were off. If I can, I will do one bolt at a time.
Old 05-18-2002, 11:26 AM
Senior Member
targa88's Avatar
It is a fairly simple task for a DIYer. You don't mention which model you purchased. However, the only caveat -when undoing bolts, you must be careful not to undo the bolt that adjust the wheel camber; otherwise it will be time for an alignment.
Targa 88
www.pelicanparts.com/gallery/targa88
There is speed.... and then there is VELOCITY
Old 05-18-2002, 05:33 PM
