plumb4u2's Avatar
oil usage?
I have read many posts of people saying their car burns oil at a rate of 1QT 300-800 miles
My question is, I changed my oil last winter with Brad Penn and probably put around 1K miles since
I took my car out last night cause the weather is awesome right now in the NE and when I got home and car was nice and hot I checked the oil and it is smack dab in the middle where i put it
My 84 has 92k on it and I bought it in summer of 2010 with no service history or PPI (I know dont flame me)
Is this just a sign of a nice tight motor
Just curious Thanx
Justin
84 Carrera Targa
98 F-150 4x4
Old 03-13-2012, 10:49 AM
Porchcar guy's Avatar
Do A Dance :=)
Sounds like you have a tight motor with little useage. Good Find !
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 03-13-2012, 12:11 PM
I bought my '86 Cab in January and drove it from Ann Arbor, MI to Winchester, VA. The oil level was right in the center of the stick before I left Ann Arbor. As of today I have driven the car over 1,100 miles and the oil level has not moved. The engine has now close to 68K on it. Yes, the weather is great and I'm driving it top down.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 03-13-2012, 12:36 PM
76 911S Targa
My 85 did not use oil between oil changes.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-13-2012, 01:24 PM
dshepp806's Avatar
My 89 will only need about 1/4 to 1/3 of a quart (at best) over oil change intervals @ 3K miles....VERY tight....and I bet 1/2 that is from a couple of testy VC nylocks.... VERY HAPPY with this rate of consumption, in light of what Porsche specs......(amazing).
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-13-2012, 01:36 PM
3200 miles since the last oil change on my '85 and i haven't added a drop!
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 03-13-2012, 01:38 PM
Banned
My 85 was overfilled when I got it, so my use might not be the same from start to finish.
It is not yet at the mid-mark, and when it is, I will start to calculate. But my estimate is 1qt/2500 miles, if I'm right about accelerated usage when overfilled.
Old 03-13-2012, 01:42 PM
Spiderman
Jesse16's Avatar
My 87 uses about a quart every 1000 to 1500 miles, I'm told thats very acceptable. Luckily my oil level gage seems to work and I'm still chicken so pull the stick ever other fuel fill.
Before re-build, I was using a quart per fuel fill. As we all know, the level is hugely dependent on engine temp..
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 03-13-2012, 01:56 PM
Registered Interloper
My '88 uses 1 qt every 2000 miles. I change the oil at 3000 and add 10 1/2 quarts BP to land square in middle of the dipstick.
Bjorne
'88 CE Coupe
Old 03-13-2012, 02:34 PM
