-   -   rear seat and shifter console delete (http://forums.pelicanparts.com/porsche-911-technical-forum/665256-rear-seat-shifter-console-delete.html)
krshome 03-13-2012 06:03 AM
Hey all, I'm looking for some help. I want to remove my rear seat completely, I do not want to install a rear seat delete shelf. What are people doing to give it a clean look. Do you just redo carpet and is it easy? As for the center console I would like to remove that as well, how and where are you moving rear defogger and hazard switches. Photos are the best. Thanks all
ivangene 03-13-2012 06:14 AM
rear fog switch is under the passenger foot rest...I never seem to miss it - also hazard in same place but I have access to that one in case I need to hit the button....
I think its a poor execution on my part but it really hasnt been an issue...no new holes drilled, no goofy brackets and completely reversible
McLaren-TAG 03-13-2012 06:28 AM
Here's mine, cleaned things up a bit since then, painted the stick etc.
http://i1193.photobucket.com/albums/...e/dsc_3018.jpg
fred cook 03-13-2012 06:30 AM
Seat delete...........
I did this on my SC recently. Removed the (entire) interior, put down some dynamat sound deadner and RS carpet set. In my car, all I had to relocate were the two a/c controls which I put in a panel where the ashtray used to live. The seats are by Corbeau (17 lbs each) as are the seatbelt/harness assemlies. Door panels are RS style with no pockets and strap door releases.
http://forums.pelicanparts.com/uploa...1331644812.jpg
http://forums.pelicanparts.com/uploa...1331645034.jpg
http://forums.pelicanparts.com/uploa...1331645223.jpg
