Woodyhfd's Avatar
Anybody know the angle of the floorboard?
The wooden floor board on my 83 911 SC was beyond repair so I used it as a pattern and cut one out of aluminum. I need to bend it like the one that Rennline sells, but I need to know the angle. Does anyone have one on the bench that they could measure for me? Even just a photo of the profile of it would probably be enough for me.
Thanks.
1987 911 Coupe, Diamond Blue Metallic
2006 Cayman S, Seal Gray
1983 911 Targa, Black: The Dirty 911 (GRM)
Old 03-16-2012, 12:20 PM
steely's Avatar
not a profile - but maybe you can use this until someone chimes in?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-16-2012, 12:42 PM
Local Mad Scientist
Andy911sc's Avatar
Thanks.
And I thought mine looked rough. I have what will probably end up being a stupid question, but what is the metal bracket at the top where the clutch pedal goes through? Is it just a support stop so the clutch doesn't break the wood?
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-16-2012, 12:55 PM
Woodyhfd's Avatar
Thanks for the photo. That gets me a little closer.
Old 03-16-2012, 02:24 PM
steely's Avatar
Woody: I ran down and did an unsophisticated measurement 32 degrees, but 30 is probably correct.
This is for the angle of the bend in the board. (edit)
HTH
Andy: that is the clutch pedal stop and cable be used to set the clutch release a bit for cars with clutch cables. 2 allens hold it and it can be slid up or down a bit.
Dan
Venetian Blue
Old 03-16-2012, 02:39 PM
