-   -   Stuck in Reverse AGAIN..... (http://forums.pelicanparts.com/porsche-911-technical-forum/665455-stuck-reverse-again.html)
SweetWaterSurprise 03-14-2012 05:47 AM
So I had this stuck in reverse and first issue before. I worked on it several times and got it resolved by just pushing the transmission pin back in. I ended up actually making a new pin and that seemed to work for a while just fine. Now I am constantly having the car get stuck in reverse. Tried to take it out this morning, as soon as I put it into reverse the car got stuck that way. What can I do to have this stop happening? The new pin I made it slightly longer then the one that was originally in the car. I went by another thread from this site for size requirements. Any help is appreciated.:confused:
SweetWaterSurprise 03-14-2012 06:42 AM
Bit more info. My car has a 915 Trans and a Wevo shifter. I can also shift into every gear freely, but still stuck in Reverse.
lindy 911 03-14-2012 07:33 AM
My problem was that the coupler was not aligned properly with the input shift shaft. There is a process to follow when mating the two parts. I'm sure there's plenty of info with a search.
SweetWaterSurprise 03-14-2012 08:05 AM
Yeah I see that now with a few different searches.
john walker's workshop 03-14-2012 08:45 AM
usually it's because the trans was apart previously and one or both of the detents in the diff housing and/or center housing were not installed properly. these are not the two under the 17mm wrench sized bolts. disassembly required to fix.
SweetWaterSurprise 03-14-2012 09:10 AM
Ugh, thats what I was afraid of.
john walker's workshop 03-14-2012 10:46 AM
there are two T head plugs closing the drillings for the detents on the top passenger side of the diff and center housings. they pry out and tap in. if you can see the rounded end of a detent down the hole, it's in the wrong place. mirror and flashlight required if it's in the car.
SweetWaterSurprise 03-14-2012 05:55 PM
Thanks for the help. New issue. I got the pin pished back in, went for a drive. Parked the car after 20 minutes on the road. Now it doesn't start. No clue why that is.
DRACO A5OG 03-14-2012 06:00 PM
Check ground at trans.
Will it push jump start?
SweetWaterSurprise 03-14-2012 07:26 PM
I'll do that. Not sure about a push jump start. I just pushed it back in the garage for now. I'm not sure what could have happened. It cranks like it's going to start, gets close then just doesn't.
DRACO A5OG 03-14-2012 07:30 PM
Cranks?
What is the voltage of the battery?
Also year of car will help allot.
snbush67 03-14-2012 07:39 PM
The no start issue may be your fuel pump relay, you may be able to switch the red and the black to check it.
SweetWaterSurprise 03-15-2012 10:26 AM
I have a seperate switch for my fuel pumps. I can hear them kick on. The car is an 82, but has a 3.3 Turbo engine and 915 trans. Battery has solid volts.
snbush67 03-16-2012 02:14 PM
Next would be spark then, pull the cap and check the condition of the rotor. Pull a wire and check to see if you getting spark?
