vinny c's Avatar
Front shocks
Replacing Bilsteins up front. There is mention of adding 50ml of oil for cooking purposes.
How is this done without purging oil when inserting new shock?
Vince
Old 04-05-2012, 07:11 PM
Hi Vinny,
Its not for "cooking" (I'd do that using the exhaust manifolds), but its to help the shocks transfer heat to the strut tube. This makes a significant difference in performance and well worth the effort.
I don't usually bother purging the old shock oil; I simply pour 2-4 oz of either 10w oil or anti-freeze into the strut housing before inserting the new cartridges, letting any excess to simply self-bleed over the top as you tighten the nuts securing them into the strut body. Clean everything up and you are done.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-05-2012, 07:29 PM
vinny c's Avatar
Steve,
If I put the oil in and insert new shock, the oil is forced out thru split pin opening and pretty much a waste. What am I doing wrong?
Vince
Old 04-05-2012, 07:54 PM
Do you have Boge (black) or Bilstein (green) struts?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-05-2012, 08:57 PM
tazzieman's Avatar
What he is saying is that the Bilstein inserts pass through a hole in the bottom of the strut housing , thus any oil will just pee out the bottom.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 04-06-2012, 02:48 AM
na2ub's Avatar
I believe the Bilsteins are "upside down" inserts, meaning the hydrolics are on top and the non-hydrolic shaft is in the housing. There is no need / advantage to oiling the strut housing. They are fine as is.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 04-06-2012, 06:26 AM
vinny c's Avatar
Yes, they are Bilsteins.
Thanks to all for the help.
Vince
Old 04-06-2012, 07:09 AM
