-   -   A/C Relay Question - front condenser fan inop (http://forums.pelicanparts.com/porsche-911-technical-forum/665825-c-relay-question-front-condenser-fan-inop.html)
mthomas58 03-15-2012 07:27 PM
Turned A/C on for the first time this year and performance was not good - I appear to be low on refrigerant. Rather than evac and recharge I opted to try topping off the charge using gauges. While working on the system I noted that the front condenser motor was not engaging. Unplugged and tested motor by direct connect to the battery and it works fine. Swapped #1 relay on the fuse panel and no change - still inop. Everything else appears to be working (compressor, evap fan and fans on aux condensers (2) in there rear wheel well). My question is does the A/C relay in the smuggler's box control the activation of the front evap fan relay and could that be the source of my fan problem?
Front condenser fan is fuse protected. I checked that fuse and all other fuses on the panel and all is good.
Bob Kontak 03-15-2012 07:53 PM
I think that is the case. However, I do not have enough experience to say for certain.
You can download the Bentley manual from this site and look up the wiring for your application.
Manuals
Mysterytrain 03-15-2012 08:17 PM
From the SC bentley: The AC temperature switch controls the compressor clutch and the relay for the front fan.
Bob Kontak 03-15-2012 08:25 PM
I have an 81 SC and I do not think I have a relay in the smuggler's box. My pal's 89 930 does have a relay in the smuggler's box and this would be the same system as the OP's car. Hence the suggestion to look at the Cannell Bentley manual.
howard freeman 03-15-2012 08:44 PM
If your SC doesn't have a relay in the smugglers box,its not factory A/C.
Howard
howard freeman 03-15-2012 08:48 PM
Fuse 20 powers the relay for the aux fan. Try rolling or replacing that fuse,they will corrode,use only copper element fuses. No Aluminum !!!!! The relay for the aux fan is seperate from the system relay in the box. That one is on the relay panel. electrical diagram is here on this site.
Howard
Bob Kontak 03-15-2012 08:51 PM
OK - Cool. You are probably right. I never had issues with the evap fan working. I do not remember seeing it but will do a visual check asap.
Arne2 03-15-2012 08:54 PM
I had to replace the relay in smuggler's box on my '84 when the front condenser blower didn't work.
kuehl 03-16-2012 05:10 AM
Mr. Thomas,
Follow Mr. Freeman's lead on this one.
Roger Shultz 03-16-2012 05:38 AM
Also check the connector to the fan. Mine was bad.
db_cooper 03-16-2012 11:35 AM
There is a fused update harness for the front condenser blower motor. If you don't have it, it is a very good idea. It is available from out host. Part number OEM-911 612 077 00
If you do have it..check the fuse.
mthomas58 03-16-2012 11:58 AM
Got it and have checked the fuse. All good there. Thanks!
mthomas58 03-16-2012 01:04 PM
Howard
The fuses all look OK but I do have some Alum that I will replace with copper. I need to check the wiring to the fan relay socket.....had battery replaced recently and something could have been pulled loose.
I have not opened up the smugglers' box yet to check the relay (I've ordered a new one already as I did not replace it when I did my A/C system 2 years ago. On drive back from a trip this AM I had the A/C on to test function and I started to get a hot electrical smell so I shut it off. All of the wiring, fuses and relays outside the smugglers box look OK so I am anxious to see what going on in there.
COL 911 03-16-2012 01:06 PM
If you are getting power all the way to the fan motor, you may want to check the inlet side of the motor housing as well as the flow through area behind the bumper. The photos show the culprit I found a few years ago, unfortunately, my fan motor had self destructed long before I discovered the wad of paer inside which was binding the cage fan.http://forums.pelicanparts.com/uploa...1331928367.jpg
http://forums.pelicanparts.com/uploa...1331928381.jpg
mthomas58 03-19-2012 10:43 AM
No update yet. Smugglers box A/C relay arrives tomorrow and I did not get a change to work on it this weekend. I've now got two projects on my to do list. Fixing the A/C and installing a driver's side fender oil cooler from Elephant Racing that arrives today and was ordered prior to the A/C failure. Hoping to lower my oil temps this summer by 15+ degrees.
The smell was reminiscent of the melting A/C #1 fuse issue that I had several years ago before the Griffiths upgrade so that was the first place I checked and the fuse was OK. At that time, IIRC an overcharged system was part of the problem as an evac and proper charge at the dealership solved the overheating fuse issue.
mthomas58 03-22-2012 05:15 AM
As a reference, I'm adding a link to this thread with good info on the A/C relay in the smuggler's box. My new relay with the external fuse arrived yesterday, according to this tread, was introduced with an external fuse vs internal diode in 88+ years.
http://forums.pelicanparts.com/porsche-911-technical-forum/103419-c-relay-location.html
mthomas58 03-22-2012 05:32 AM
More thread reference info. Link to A/C wiring diagram:
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_AC.jpg
kuehl 03-22-2012 08:45 AM
15 amp ac relay?
So... terminal 87 on the ac relay in the smugglers box is "suppose to" support:
a) an evaporator blower motor that draws 12-15 amps, depending upon conditions , plus
b) a compressor clutch coil that draws 3-4 amps, depending upon conditions,
At this point we are consuming 15 to 19 amps, depending upon conditions, and then we add:
c) other circuit items that consume amps, which include all wiring to things like the blower switch, bimetallic switch, thermostat, dme, front condenser blower motor's relay coil, compressor clutch, and the 'conditions' or integrity of the wiring as a whole and at each junction such as terminal connection or splice. Conditions can include things like the integrity (corrosion, effective contact surface of a terminal, number of complete strands intact) and temperature, air density, efficiency of a motor, etc.
Food for thought side notes:
i) I recall a very knowledgeable and experienced tech whom installed a blower motor in a clients car. He said the AC relay immediately failed after the installation. I asked him what amp relay was in the car and he told me 'factory original'. I suggested replacing it and checking the amp draw on the motor, and to 'run it over night and see if dies' before releasing the vehicle to his client. Well the client picks up the car, drives 1300 miles south and along the way the ac blower stops working. He visits another shop and the tech there inspects the relay, said it failed and it was a 15 amp relay. He also tests the evap motor and "feels" it might be drawing a bit more amps than normal. He installs a new evap motor just in case and replaces the 'factory relay' with a 25 amp relay. Client drives away happy. We get the evap motor back and test it. Its normal. The tech whom originally installed the evap motor calls us and demands we reimburse him because his client had to pay the other tech 1300 miles away. And he insists he installed a 'new factory relay'. Another story. Anyway, we further test the questionable evap motor on a bench for 6 months running in variations of 1 hour, 3 hours and 8 hours of continuous use. No problems. We run it in a car for 3 months using a 15 amp and 25 amp ac relay. No problems. Its a normally adjusted and happy motor. Moral to the story.... "conditions can be different in different cars". Use a 25 amp relay.
ii) A few months ago we finished a respectable client's ac upgrades. We test drive the car with the client, stop to chat, and he's happy with the work. He climbs in the car and turns the key and it won't start. OMG! I feel the anxiety of expectations face me. What now? But I'm lucky. He is very patient. He asks "so, what did you think?". OMG, where do I start. So I think about all the possible places we worked that might affect ignition and fuel supply, and frantically go over the car.
Check this. Check that. Wiggle this. Wiggle that. All wires look good. Suddenly the car starts. He says "So. What did you touch?" I tell him all the points and we ponder. Then, suddenly, thanks to having a mind like an elephant and total photo recall, I say "You know, my 87 did that before. Won't start after its warm. Hmmm, doubt its the coil.... hmmmm, Hey I got! DME Relay! Happened to me." "You think?"
"Well, I'm not an expert but its what I changed and it fixed the problem". So he drives away. Takes the car to his full tech. And the tech replaces a fuse. He drives away. A week later he calls me and it won't start again. I tell him "try the DME relay, alot of techs tell me they keep spares in the glove box". So he replaces the DME relay and advises me over the next month that it fixed the problem. Moral to the story.... statistics can be your best approach to solving car problems.
iii) Yesterday a tech calls and says a client's SC ac system is not consistent, the evap blower motor and system shuts off on its own sporadically, it has a mind of its own.
The tech and I go over the upgrades the client's car has and we ponder circuit points to check. 3 hours later the tech calls back, "You are not going to believe this, the relay is good however the yellow wire which goes back to the starter was loose at the starter". Moral of the story....."Hey, I learned something today!"
mthomas58 03-22-2012 09:27 AM
Griff, great info. So you are suggesting using a 25amp vs 15amp relay in the Smuggler's Box? If so, being more of a banker than an electrician, is that as simple as changing out the fuse on the relay or do I need a relay that is engineered for 25amps? Note, mine is stamped 12V/15A. Here are pics of my new OEM Porsche relay obtained up from the local dealership.
Thanks!
Mark
http://forums.pelicanparts.com/uploa...1332433488.jpg
http://forums.pelicanparts.com/uploa...1332433541.jpg
kuehl 03-22-2012 10:43 AM
Mark,
Here is my opinion:
If you toasting a relay and its not because the relay is worn, then something (component or a circuit) is drawing more amps than it should.
First you want to determine if the circuit has good integrity (switch contacts, terminals, wire).
If you have a failing switch, poor terminal contact or frayed wires, fix them.
Second, check the individual components (motors) to insure they are not drawing excessive amps; meaning above what they are rated to consume. Replace those that are, such as a failing front blower motor or whatever. We had a client last month that kept popping a fuse, it ended up to be a brand new Spal brand blower motor on an add on condenser (even the best can fail at times).
A simple inexpensive amp panel meter comes in handy to trouble shoot problems
Third, if the relay is not sufficient enough to support the demand, such as having 19 amps of clean demand but only having a 15 amp relay, then replace the relay with a 25 amp. A 25 or 30 amp "AC" relay is very common, get one with the same pin outs. You don't need a relay with a fuse but you could simply put an inline fuse off of terminal 87 if you wish.
Griff
wwest 03-22-2012 05:41 PM
Kuehl...
There's more involved in a relay's operation than just allowing current to flow or not. Any type of inductive load, many are, turned continuously on and off over the years and the contacts will erode away. Sometimes you can have an average current, measured by a meter, well within the rated range for the relay (or fuse, think fuel pump) contacts, but with DC motor startup or pulse content 10 times higher.
fred cook 03-22-2012 06:06 PM
Fuse #20
Howard
This fuse powers both the front condenser fan and the evaporator fan. If you do not have the headlight washer option, move one of the fan wires (bottom of the fuse panel on fuse 20) to fuse 19. This will make your old fuse panel much happier!
Or, you could go all out and buy one of my ATO fuse panels!
kuehl 03-22-2012 06:10 PM
West,
I agree with you. Hammering a 15 amp rated relay with 19+ start up loads for milliseconds, seconds, or minutes, and continual seasons of 19 amp average loads will surely erode or fuse the contacts. Good point !
Griff
Jim727 03-22-2012 07:04 PM
I'll endorse that. After my a/c upgrade I kept blowing the fan fuse any time I got the blower over about half-speed. I really didn't want to increase the fuse size on old wiring so I split the front fan off on its own circuit. Problem solved.
Any chance you'll make ATO boxes for the earlier cars?
fred cook 03-22-2012 08:55 PM
Earlier cars..........
Working on it. I need to get an up close and personal look at the earlier fuse panel mounting brackets to get some measurements, etc. Eventually I hope to be able to cover all years from 1965 thru 1989.
kuehl 03-23-2012 07:26 AM
http://forums.pelicanparts.com/suppo...s/beerchug.gif
mthomas58 04-01-2012 07:49 PM
Finally had some time today to work on the A/C. Opened up the smuggler's box to replace the A/C relay and found the source of the burning electrical smell. Terminal #30 on the A/C relay socket has melted. Swapped out the relay and the front condenser fan is still inop so more troubleshooting is needed. I do plan on moving the power source for the front condenser fan from fuse #20 to #19. Additionally, I found that one of the fans on the dual rear fender condensers is inop. More work to do in several areas.
http://forums.pelicanparts.com/uploa...1333334752.jpg
http://forums.pelicanparts.com/uploa...1333334803.jpg
kuehl 04-02-2012 04:46 AM
Mr. Thomas
Your relay appears to be original?
What is the amp rating stamped on it?
http://forums.pelicanparts.com/uploa...1333367178.jpg
mthomas58 04-02-2012 05:17 AM
It does appear to be original as it is stamped 10/ 86. Amp rating is 30A.
http://forums.pelicanparts.com/uploa...1333369000.jpg
kuehl 04-02-2012 06:27 AM
Thanks Mark.
I assumed 30 amp was stock out of the factory.
So, did you order a 15 amp or 30 amp?
mthomas58 04-02-2012 07:46 AM
I ordered the factory replacement from the Dealership - 15A which is installed.
Now trying to figure out how to move the front condenser fan power source from fuse #20 to fuse #19. Not readily apparent from looking at the fuse panel - .....and I just figured out that I was looking for wires per a 82 Wiring Diagram. Need to locate the correct one for a 1987. Looks like I will need to pull the panel and look behind it to see where the power for the front condenser fan ties into fuse #20 (center blue fuse on three fuse block - far left side of photo)
http://forums.pelicanparts.com/uploa...1333377745.jpg
mthomas58 04-02-2012 09:04 AM
While down, I've decided to go ahead and replace the Temp Switch which I think is also original.
kuehl 04-02-2012 09:08 AM
The factory relay was a 30 amp.
The 'factory' replacement is a 15 amp.
However the load is equal to or greater than 15 amps.
Think about it.
mthomas58 04-02-2012 12:23 PM
OK, 30A relay ordered. Here are a couple of great pics from a fellow Pelican on how to move the front condenser from fuse #20 to #19 to reduce the load and heating on fuse #20 as suggested and done by several folks here.
http://forums.pelicanparts.com/uploa...1333394004.jpg
http://forums.pelicanparts.com/uploa...1333394051.jpg
Remaining project to do's:
(1) Replace 15A new factory replacement relay with 30A relay in accordance with orig relay spec.
(2) Replace Temp Control Switch
(3) Relocate front condenser relay power source to fuse #19 (a/k/a #3) per pics above. A/C fuse is #2 on the small 3 fuse block from back to front and #19=#3. Multiple references found - Bentleys lists the fuses in three blocks and the cardboard fusebox lists the fuses from front of the car back.
(4) Finish troubleshooting front condenser inop situation. Fan works fine if hardwired to battery. Check condition of panel relay and relay socket wiring.
(5) Troubleshoot front rear fender condenser (fan inop). Rear fender rear condenser fan on same circuit is working fine.
(6) Recharge upon completion of 1-5
mthomas58 04-05-2012 08:57 PM
Update: Headed over to Augusta today for the Masters. Possibility of picking up my boss at the airport in Columbia so I thought I would try to get the A/C working or would have to rent a car.
Confirmed rear fender spal fan on front condenser dead. Happened to have a spare from my deck lid 3 fan project that I did not use and is identical to the dead fan. Replaced and problem solved.
Tried jumping front condenser fan relay socket - nada. Finally figured out that the relay socket is mounted in the fuse panel with pin 30 at the 3 o'clock position. All other relay sockets have pin 30 at 6 o'clock. I did not think that the relay could be inserted at any position other than correct. WRONG - I had pins 85 and 86 where 30 and 87 should have been so the fan has been inop for I don't know how long. What a dumb ass!
So, except for installing the 30A relay (vs the new 15A A/C relay) and replacing the temp switch (both arrive tomorrow) and moving the front fan to fuse #19 all components are operational so I though I would charge the system and give it a try. Pulled vacuum and charged system for the trip and the A/C ran great all the way!
Life is good again!
db_cooper 04-06-2012 04:43 AM
Pretty cool here in Georgia this morning..you may not need the A/C after all. A report on the Masters is required.
http://t1.gstatic.com/images?q=tbn:A...JJu2ufC1xsXNBr
86 911 Targa 04-06-2012 07:15 AM
Evaporator relay current loads.
Life is good again!
Yup, it is possible to install the round fuse panel relays out of circular alignment.
Your evaporator relay appears to have died a very slow death due to contact arcing/pitting,
thereby creating a series resistance leading to contact overheating.
Our '86 came equipped with a 15A relay, which I replaced with a fused 15A relay.
Also, please have a second look at the pics I sent.
T
Also, the front condenser blower fuse has been relocated from fuse #2 to #3.
Here are some A/C current draw values I recorded a while back:
http://forums.pelicanparts.com/uploa...1333720957.jpg
Evaporator Blower Motor Current-Low Speed.
http://forums.pelicanparts.com/uploa...1333720999.jpg
Evaporator Blower Motor Current-Medium Speed.
http://forums.pelicanparts.com/uploa...1333721026.jpg
Evaporator Blower Motor Current-High Speed.
http://forums.pelicanparts.com/uploa...1333721058.jpg
Front Condenser Blower Motor Current.
