I mean can u feel it loosing spring until they brake? Or u will only notice they are bad after they brake?
Senior Member
MM,
Any spring steel will loose a bit of its tension over time. I have had one torsion bar break in almost 20 years of driving 911's and that was in Germany when a tow truck picked up my car on the street. They lift it up with a overhead crane and I believe that they "yanked" it too hard and one bar broke... sagged to where the tire hit the fender lip anytime you hit a bump. Other than that you may notice a slight difference in the ride height but unless you bought a car, measured its ride height and then drove it for many years then measured it again would you really see any difference IMHO. JA |
My rear suspension is set at 26" height and my passanger rear tire is rubing the fenders....I dont feel it but there is a bubble in the paint and in the inside you feal the bare metal.....
Can this be the torsion bar? Going stiffer will help? |
Senior Member
Hello
Torsion bars will not sink down like a coil. They only brake if they have a "weak spot" mostly caused by rust piting. On the other side the rubber parts do wear out and this is the major issue. I never heard that the torsion bar brake while driving. And I renewed some from them the rear ones are a hard job if the brake in the inner end. Grüsse |
