krshome's Avatar
Whats this?
Under my drivers seat on my 88 Carrera there is a brass cylinder ( bell like ) next to the DME. What is it? Its vibrating like crazy is there a way to tighten it up, to stop the vibration noise?
Old 03-16-2012, 07:01 AM
The exact name escapes me right now but it is your altitude sensor. Is the base secured to the deck and something inside is rattling around? I think it is a single unit so inside rattling (mine doesn't) I doubt can be tightened. Try putting a piece of carpet foam under it to see if that padding doesn't isolate it a bit. Also looks like the DME is touching it, are you sure those two aren't vibrating off each other?
Thanks,
Chris
1980 Targa, 3.2 upgrade
Old 03-16-2012, 07:21 AM
Brad394's Avatar
That is the altitude sensor - as for stopping it from vibrating ??? solid motor/trans mounts and remove sound deadening material
Brad - 86 Carrera (Doc)
Old 03-16-2012, 07:23 AM
krshome's Avatar
Is the altitude sensor designed to be loose or should it be solid? The top and bottom are loose and spin the mount for the sensor in secure. I moved the DME so it does not touch no difference. There is a screw on top but it feels like it's attached to a spring inside the sensor. I don't want to break it. It never was a problem before, so weird.
Old 03-16-2012, 07:51 AM
if the round cylindrical part is loose in the mounting bracket, apply a couple dabs of silicone caulking to the joint and that should take care of it
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 03-16-2012, 07:57 AM
krshome's Avatar
Thanks I' ll give that a try
Old 03-16-2012, 09:29 AM
