-   -   Help!- Can You Identify These Ignition Switch Terminals (http://forums.pelicanparts.com/porsche-911-technical-forum/665957-help-can-you-identify-these-ignition-switch-terminals.html)
combatic 03-16-2012 01:26 PM
Can anyone help me sleuth/sort out my ignition switch terminals? I need to swap ignition on left with ignition on right. (I was a dumb dumb head and yanked working ignition from the donor car thinking it was a straight swap and viola' ....different!! :o)
I used the '1965-' wiring diagram to identify the wires for the switch on the left. I think it is right:rolleyes: (there is no diagram for 1969 on Pelican? Is this right for my MY?) There is also no 1977 wiring diagram that I can find so I am stuck.
https://lh3.googleusercontent.com/-f...2520Mayhem.JPG
Ignition on Left- came 'as is' and is just a cylinder that you can insert a screwdriver in and rotate as if it is a key. (I think I have the wires sorted
Ignition on Right- came in donor car and worked. I assume it is from a 1977S as the motor and other parts came from a 77' BUT it is a short key?
I have searched Pelican and the WWW but I am stuck. any help would be greatly appreciated!
steely 03-16-2012 04:45 PM
This thread (espec. posts #'s 3 & 15) may be of interest:
http://forums.pelicanparts.com/porsche-911-technical-forum/361429-1968-swb-turn-signal-park-lamp-operation.html
I searched for 8276.
combatic 03-16-2012 04:49 PM
Dan, Thanks for the link...I think that gets me closer in solving this mystery!
