correct air compressor 1984 Carrera
For a 1984 Carrera, i have 2 air compressors for inflating the spare, one goes to 20 bar / 300 psi and the other 15.4 kg/cm 220 psi both in the same common black case, wich is the correct one?
The spare is the silver/grey 15", hopefull and offcause in denial, i never have to use either, thanks for any advise. Last edited by pingpong; 01-30-2012 at 08:46 AM.. |
Post pictures of the insides
they have both the same common black cases but different PSI, not visible on pictures. Please anybody with a 1984 Carrera can check? Thanks
please help, nobody?
Hi, I have an 84 Cab, I purchased in 86. I have the original tool kit ect. I do not have a compressor unless it under the spare. I have never needed the spare.
The car is in winter hibernation, but I can get to it. My question,was a compressor standard issue? Bob |
i bought the car used with 2 air compressors, would like to know wich one belongs to the car, appreciated.
post a photo of both of them
1988 Carrera Coupe |
I have a ROW 1984 model and it has the orange compressor, which I believe is correct for that year.
No sure for US models..... Cheers, Geoff.
1984 911 Carrera....... |
Psi ?
please my only question is about PSI? i have 2 common black cases, but different PSI, not visible on any picture, please anybody its only about PSI. Appreciated, thanks.
If you are asking the correct tire pressure, then look on the tire sidewall.
The sidewall will show the correct tire pressure. The collapsable spare should say something like "30 psi" or something like that, which will be around 2 bar. Hope this helps. |
I'll take a stab at this, having had an '85. Pretty sure the higher PSI one you have is correct for '84. It should also have the larger-diameter cigarette lighter plug. HTH.
Jon '85 930 |
