Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
300hp 1800lbs is the goal
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Honey Badger
I am interested in these as well. Has anyone had success with the fiberglass ones? A steel version sure would be nice.
1978 911SC 1953 Piper PA-18A USAF EOmfD |
They are not bad to fabricate, particularly if you have the short hood fender filler pieces and the Porsche signal light frames which I think are 901 503 043 23 GRV and 901 503 044 23 GRV.
A small piece of sheet metal, bit of welding and off you go. Oh yeah, you have to bend down the front flange on the shorthood fender to hold the signal light. Dennis |
Interesting - I wonder why they chose to do the earlier light boxes and not the later. I did not realize there was a difference until I looked closely.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Tony
Did TRE ever come out with the steel turn signal boxes?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 03-24-2013 at 11:04 AM.. |
Honey Badger
Bump for vendor updates. Would like to know about current availability of metal light boxes for LWB cars. Trying to avoid paying top $$$ for older fenders if I can help it...
Vic +++++++++++++++++++++++++ What the FUCH ? 1977 Porsche 911S 3.2L Frankenstein |
I hand made a set as Iciclehead suggested, but it did required a great deal of patience. Not real pretty, but they will not show.
Jeff Graham '56 Speedster '72 911E Targa |
okay- update 10.18.16
We gave up on our USA based metal guy. Frankly these were causing him a head ache to make them. So we connected with a european based outfit about 4 years ago, and import these conversion parts. We currently have inventory, and cost is $700 a pair. BUT heads up as these parts are not 100% correct ready to weld on. They do need some manipulation/ small mods to get them right. We have gone over this with the manufacturer, but they claim the product is perfect . NOT. so no changes Still it is decent enough to work with and we have sold approximately 100 sets so far. Our body shops have installed them, so talking from personal experience' And sorry: NO turbo / RSR version planned at all ![]()
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Which front fenders are these applicable to? Mid-years, SC/Carrerras, etc.? Or do they all have the same front fender dimensions? Thanks.
2014 Panamera Turbo Executive 1982 911SC Targa - Guards Red 1983 DeLorean (Sold) 2001 996TT - Lapis Blue (Sold) 1995 993 C2 - Grand Prix White (RIP) |
Thanks for asking: Yes, the grey/green metal you see is what you get to weld to your car. The turn signal assembly, lenses, horn grills are available separately.
These fit 1974-1994 fenders
Ok. So for something with late 60's fenders like a 912 and the quarter panel would either have to be changed out, or the fenders modified right?
Very good !!
kinda slow
Wanted to bump this. Anybody DIY'd this? Any tips?
1983 911 SC Coupe |
Full Send Society
I just did this with the weld-in metal versions. There are photos in my build thread.
Basically; After you have your long hood in place you need to cut the bottom of the fender off, maybe a centimeter, just enough to get rid of the bottom and enable the new light box frame to slide over the fender. You may have to do some additional cutting where the fender needs the front bulkhead wall to create clearance for the light box. I did, but be careful because there’s a mounting bolt there that you don’t want to cut. You’ll also probably have to trim some of the light box frame to make it fit. Once you can slide the fender up you need your bumper. You’ll have to position the bumper in its place and then align the light box with it- this is a matter of tilting, twisting, bending and forcing the light box into position so that 1.) the light box fits into it 2.) the frame fits on the fender and 3.) the frame aligns with the bumper. There are no other specific instructions other than to work the light box over and over. Do both sides at the same time otherwise you may be off and not know it. When in place you then need to trace the top edge of the light box frame onto the fender. This will be your cut line for the butt weld. Cut close to the line but be careful. Test fit, trim, test fit, trim… use a sander to nibble away until you have a really tight fit. Clamp everything in place and begin welding. The light box frames are significantly thinner than the fender metal so keep that in mind when clamping- most clamps won’t hold the outer face flush so you will likely have to hold it while tacking it in place. My light boxes were so thin (26-28 ga) that I wasn’t able to successfully TIG weld them as I’m not that good, so I MIG welded them and then ground the welds and did hammer and dolly work where I could. Here are some photos of mine and others that I found: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
kinda slow
Great stuff, thanks for the info. It seems getting steel fenders is hit and miss and they often need working as well, so I wonder which is easier.
1983 911 SC Coupe |
| Tags |
| backdate 2.7rs conversion |
