1980SCMan
Help Please - Engine Hesitates (Bogs) Under Load
1980 SC. At first I thought that my clutch was slipping. I did the 5th gear pull from 25 mph and there's no slipping. Clutch is a Sachs with less than 25,000 miles.
Perfect idle. Revs in neutral are clean and crisp. But when driving (in any gear) the engine seems to bog and hesitate and stumble under load. It's been raining a lot. Could be a bad tank of gas. Could be bad timing. Could be clogged fuel filter. Could be poor spark. I have a "tired" fuel pressure regulator that causes rev surge in cold temps, and I haven't put the pressure gauge on to confirm pressures, but other than idle, the engine runs strong when when ambient temps are > 50 degrees. Have an 8 month old rebuilt Bosch ignition box, 18,000 mile Bosch plugs, 120,000 mile+ ignition (shielded) wires. Cap and rotor look "ok" but not fresh. Where's a good place to start? This is a daily driver with 250,000 miles on the motor. Last edited by Alan Lindquist; 03-19-2012 at 05:50 PM.. |
1980SCMan
Bump for any suggestions?
ROW '78 911 Targa
Wires, cap and rotor for a quick, less expensive start?
Home of the Whopper
Plus spark plugs
Ignition timing Then check air/fuel ratio
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
RETIRED
CIS? First check is fuel pressure. Then fuel flow......filters.......then vacuum leaks.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Check Timing with a timing light to see if you're getting full advance.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
1980SCMan
Well... congratulations. All of you were right. Which is kind of bad for me.
1. Lean running condition from vacuum leaks at injector seals. Seals now fixed. 2. Stuck fuel injector - cleaned and put injector cleaner in the tank. 3. Lean-run plugs "white frosted" needed to be replaced 4. One spark plug boot not making solid contact - replaced 5. Timing too far advanced Now it's possible to see if the Lamda is doing it's job. Power to the unit and relay works. Need a test unit to compare. |
