Question Help-Right OR Left parking light only
On my '86 coupe, the turn signal lever in the UP position, with IGNITION OFF, should turn on the Right front and rear parking lights only-and it does. But, with the turn signal lever in the DOWN position, it turns on both Right and Left parking lights (front and rear). Any ideas what's wrong?
Old 07-29-2001, 10:24 PM
Senior Member
Post
Hello
I think the falure are the contacts in the switch. But check if something changes if you push the light switch inwards.
Very unlikly could be that the lights didn´t see ground and use the others.
Grüsse
Old 07-31-2001, 09:38 PM
