please identify this rotor
hello
the rotor on the right is one I ordered, it is for an SC the one in the middle is the current one on the car the one on the left is off a 356 The car is a 74 2.7 with what I susspect is a non original distributor I thought the one off the SC might fit but it is 60 mm while the one on the car now is 48 mm as is the 356 rotor 48mm I want to replace the middle one many thanks http://forums.pelicanparts.com/uploa...1332455922.jpg |
I beleave the part# is Bosch 1 234 332 215. Pelican says it is for a 1968-1969 912 with a bosch distributor. It also my be for a Volkswagen Beetle distributor. I can't remember were I bought mine at Pelican or a parts store. Here is a picture of what beleave to be your distributor rotor.http://forums.pelicanparts.com/uploa...1332467185.jpg
If you can't read the number it is Bosch 1 234 332 215. Try entering the number in the search block and it should come up with it on Pelican. That is the only way I found it here on Pelican. Craig. |
It's not only the length of the rotor (from center of shaft to tip)...it's also the orientation of the flat on the shaft compared to the tip of the rotor.
In other words...you might find that you need to re-index the distributor to get it back to the correct timing. Bob |
i am confused.
why would you order an SC rotor for a 74 2.7? the dist's are differenet. the early cars may be able to use a variaty of rotors. i have a 914 5500RPM rotor on my 2.7, just because i had a good one left over. |
| All times are GMT -8. The time now is 06:58 PM. |
