Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
86 911's Avatar
Send a message via AIM to 86 911
Thanks for all the help. Thank you kethunk for posting that link. I'll see about installing the resistor. If I get bored (and that is when the car decides not to break down anymore) I'll install the resistor. If this is a common condition that won't hurt anything, then I might end up just blipping the gas pedal on start-up. The battery is good (brand new) and I just haven't been driving the car which probably is the cause of the low voltage. Anyways, thanks to all who contributed. You all saved me many hours this week!
Matt
'76 Porsche 911 with '78 3.0 SC engine
'97 Mercedes-Benz E320
'13 Hyundai Santa Fe (wife's)
Old 03-25-2012, 08:42 PM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
Always learning
Mine has just started glowing ou of the blue and remains so for about two minutes, irrespective of rpm. Would this suggest belt? Or, same as aforementioned?
Cheers
Old 05-06-2012, 05:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
Joe Bob's Avatar
What is the alternator output? Is it charging?
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 05-06-2012, 08:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
Member 911 Anonymous
DRACO A5OG's Avatar
+1 get a DVM on the battery while on
'85 Carrera Targa
Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Magnecor * Targa Body Brace
PCA/POC
Old 05-06-2012, 08:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
Hi. My car have similar problems, the alternator was rebuild last week but the batery light flash few times 2-3 times when rpm are in 800-900 then turns off. This problem exist before the rebuild alternator. Any recomendation?... In adition in some rare ocations there a fluctuation on rpm from 600 to 1000 up and down, when i acelerate the car that problem is gone
Old 03-04-2013, 04:09 AM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
roadster49's Avatar
I have a similar problem. My light comes on at startup and stays on at all engine revs. Installed a new alternator checked ground wires. The light never ever went on with the old alternator even though it was not providing an adequate charge (11.4)
Old 12-07-2017, 02:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Alternator light doesn't go out after startup post #11 brings up a good point about a poor ground.
Originally Posted by Matt_911 View Post
I had this issue after repainting my fan and cleaning up my alternator turns out it I forgot to take the paint the surface where I reattached the ground wire ... rubbed it back to metal and that fixed it.
So I suppose it could potentially be caused by a bad earth on the alternator?
Old 12-07-2017, 06:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
