Setting the timing on my 82 911sc
I read in 101 projects that you should refer to Porche's Technical Specifications book for the exact timing procedure. Has anyone posted these specifications on the form or can someone point me to the information? Thanks guys.
Ignition or valve timing ? Both are covered here in dozens of posts. Reviewing all the posts on "vacuum retard" will give you the ignition timing procedure. Valve timing is covered in the Rebuilding forum ad nausem.
| All times are GMT -8. The time now is 08:42 AM. |
