Check your DME for cold solder joints, this caused a no-start in my '89 a few hundred thousand miles ago, and with your similar mileage it sounds likely. Open the DME carefully and inspect the solder under the 'stand off the board' coil power transistors, looking for a telltale dark ring 'crack'. If you see any, reflow them with a small soldering iron. Be careful with static discharge around the DME, touch metal things often while working on it.
Hope this helps, Chuck.H '89 TurboLookTarga, 332k miles |
It looks like the solder joints on these blue things broke. Plus the inside of the DME smells like smoke. So they may be toast. I think they are the only things with bad joints.
Can I just re-flow the solder joints and put it back together, or do I need new blue things? Or is the whole DME shot? And is there something that may have caused this that I should also fix? http://forums.pelicanparts.com/uploa...1332907187.jpg http://forums.pelicanparts.com/uploa...1332907209.jpg http://forums.pelicanparts.com/uploa...1332907242.jpg |
You can try replacing those burnt resistors, but the real issue is "why did this happen?" Because you will just burn the next set of resistors as well if the 'real' problem is not found.
Good luck.SmileWavy |
Looks like this guy had the same problem:
http://forums.pelicanparts.com/porsche-911-technical-forum/316374-dme-repair.html He was running two coils without a splitter. |
Wow! Those got hot.
Easy fix, but what caused it is TBD? |
Anyone know where can I buy the ref and crankshaft sensor depth adjustment tool ?
They were over-heated the result of a shorted coil primary or the use of the wrong coil - a CDI type. |
It is a real challenge to find a good coil for out 3.2s. The dealer sold silver Bosch is a 50-50 chance of buoying junk. Best bet, find a old black coil from the 80s.
Many coils of today have the wrong voltage and can cause DME problems. |
For what it's worth, i have always used an original coil, and it has always tested fine when i have checked it. |
Trying to replace both of my crank sensors as the outer jacket is just crumbling when you touch them, so not long before they will be no good. I have the screws out and I can rotate the sensors, but cannot pull them out. Anyone have any suggestions on how to get them completely out would be appreciated!
You might try soaking them with some penetrating oil and twisting them back and forth to free them up. The aluminum caps on the tips of the sensors are a tight fit in the bracket, and any corrosion on either part is going to interfere with removal. I replaced one of mine last year and it was a real PITA with the engine in the car.
| All times are GMT -8. The time now is 08:46 PM. |
