MrScott's Avatar
Smuggler's box air tight?
My car had the A/C removed by the PO. If I crack a window at speed I get a breeze from lower "bow tie" vents. I assume this is the path of least resistance for air to fill the vacuum created by the open window.
The vents connect to a tube in the smugglers box which used to connect to the A/C blower -- now it's open to the box. Is this 'breeze' typical and the fix is to seal the vent hose or should the smuggler's box be air tight and this suggests a bad seal somewhere?
1980 911SC
Old 10-12-2009, 07:24 PM
deshetlr's Avatar
There are two tubes into the smuggler's box. The first is the one going to the bow tie. The other goes to the tunnel which is where I suspect the breeze is coming from. The tube to the tunnel was an input to the evaporator box.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 10-12-2009, 07:31 PM
2Utes's Avatar
I used a rubber cap for ABS plumbing pipe to seal this tube. Friction fit seems fine, so I have a spare large hose clamp as well.
You also have a small round opening for the drain old evaporator drain in the bottom of the box and a roughly trapezoidal opeing into the passenger footwell area that could be contributing sources of airflow.
The linkage from the steering wheel to the steering rack also passes through the area and is open to the air above the belly pan.
So to answer the original question, the smuggler's box is definitely NOT air tight.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 10-12-2009, 09:40 PM
MrScott's Avatar
Good info guys, thanks!
1980 911SC
Old 10-13-2009, 05:08 AM
On my 82' SC if have an air inlet to the evaporator behind the passenger side floorboard. Is there another air let to feed the evaporator that comes from the tunnel?
Bill
Old 07-25-2012, 06:20 AM
mine has a big gap around the steering column aswell right out to the road. Is there suopsed to be a seal of some sort there? i just stuffed a rag in there so mice dont eat my tools
Old 07-25-2012, 06:36 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The round opening is the drain hole to the ground, correct? Open hole in the bottom of the car without (maybe) a hose in it.
Old 07-25-2012, 07:38 AM
Formerly known as Syzygy
Canada Kev's Avatar
Yeah, there's no way it's air tIght. With the AC removed, I would be tempted to hook up a fan there in that system as well, just to het some more fresh air into your face (dash vents) to help with cooling of the humans.
Old 07-25-2012, 08:59 AM
Flat Six
Flat Six's Avatar
Correct
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 07-25-2012, 09:07 AM
Retired, finally
SiberianDVM's Avatar
When I did my A/C delete I removed the evaporator coil from that fan box, slightly enlarged the hole where fittings exited, and epoxied in a piece of PVC pipe. Then I put a NACA duct in the front where the condenser fan was, and connected the two with some flexible duct.
The fresh air really helps, and having the fan is essential in the SE.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 07-25-2012, 09:12 AM
Flat Six
Flat Six's Avatar
Huh . . . pretty interesting idea. Any pictures you can share?
Dale
Old 07-25-2012, 09:34 AM
Retired, finally
I can take some, although my install is pretty ugly. I should have painted the PVC pipe black before I put the fan box back in the smugglers box. That fan box is one tight fit. I can see those damn Porsche engineers designing it with exactly 1mm clearance one each side.
Old 07-25-2012, 12:40 PM
Retired, finally
As promised, I am trying to post pictures of my A/C delete and fresh air intake. PVC is a 2" 45 degree union bought at Home Depot; red sleeve is 80mm silicone made for some turbo bought on ebay, but they have them at FLAPS, old flexible duct form blowr to dash vents was dry rotted; flexible duct is 3" x 4' Gates bought on ebay; NACA duct was standard single bought on ebay (had to trim end to fit when I moved my battery.
Also installed inline fuse to fan motor, as I was told this was unfused from factory.
Just barely visible is aluminum plate riveted to front bulkhead covering intake hole from deleted front condenser fan.
Haven't finished my battery cableing yet, still waiting on a kill switch kit to be delivered.
Old 07-26-2012, 04:51 AM
