First start after winter - smoke
Today I started the car for the first time after the winter, it has been standing still since late September. Before I parked it I had an O2-sensor fitted and the mix adjusted. I have also changed the oil and filter.
I first drove for about three minute to the nearest gas station to put more air in the tires. While doing that I noticed smoke coming from the rear and when I opened the lid there was some smoke in the bay but it cleared out in a minute or so and I could not figure out where it came from.
After driving for another 5 minutes I parked again and again there was some smoke in the rear but no clear source.
Is this just the engine burning off stuff that has accumulated over the winter or does it indicate something more serious? I guess I should take it for a longer drive and get the temps up...
/b
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner
Old 03-22-2012, 01:51 PM
1988 Carrera
shadowjack1's Avatar
normal after sitting up. Run it for a while.
Old 03-22-2012, 01:55 PM
RETIRED
Joe Bob's Avatar
Drive it at night....you won't notice it anymore.....
2012 ML350 3.0 Turbo Diesel
Old 03-22-2012, 01:58 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Check the seal around your engine where it meets the body. There may be some oil that dripped on your exhaust that is smoking and rising through a break in the seal. Even if so, it is not a major issue.
+1 on what shadowjack1 says.
Old 03-22-2012, 02:01 PM
Ok, I'll take it for a longer drive and see what happens.
Thanks for replying!
/b
Old 03-22-2012, 02:17 PM
My '79 does the same thing every time I get it out of storage after a few months. Maybe between a few drips getting on the exhaust/heat exchangers and the rings being a little sticky. It usually takes 10-15 miles to burn it all off/ get things loose again.
David #476
'78 911SC (gone home to the Fatherland)
'92 968 CAB
Beck Spyder #201
Too many bikes to list
Old 03-22-2012, 03:48 PM
Over the weekend I have driven it a bit more and the smoking has now disappeared.
Old 03-26-2012, 01:23 PM
