-   -   A / C 2012 spring-time it's to be hotter then HELL O (http://forums.pelicanparts.com/porsche-911-technical-forum/667729-c-2012-spring-time-its-hotter-then-hell-o.html)
KelogGes 03-25-2012 10:50 AM
HEADS UP!
Last year RECORD HEAT SUMMER TEMPS WHERE SET IN MANY Places in the USA including where I live down here in Fort Lauderdale
You should know that not only were there so many High heat temp records broken in the summer of 2011, the current temps now this spring from & before the beginning of March this winter are already causing breaking unusual records hot temps also that are unheard of.
I JUST READ THIS yesterday AND WAS KIND OF SHOCKED and thought I would share it with you guys to hopefully help you be prepared for this & what appears to be an extremely super hot summer ahead ouch as if last year was not bad enough
Record Heat Wave Grips US. But Is It Climate Change?
Thousands of temperature records have been shattered in recent weeks. Awesome or awful?
Record Heat Wave Grips US. But Is It Climate Change? | Mother Jones
I make 911 PF A/C condernsers & components and sometimes work on custom designed 911 A/C systems and have friend who owns a well known full service Porshe repair shop down here in South Florida that has A/C clients coming in much earlier than normal with A/C problems in early spring then ever before which is very unusal.
I dont know if this is global warming/changing or what? But from the indications from last summer of broken heat temp records across the USA and the indications stated in this report we appear to be set for another extremely hot record breaking year and you should start preparing your air cooled baby for what appears to be here already or soon coming
