993 windshild in 964 rubber?
Good day folks,
Is it possible to fit a 993 front windshield in a 964 rubber seal? I've seen a website selling heated versions of the screens which say 964/993 so I'm assuming it's common across both models. Just seeing if it's possible as I've got the chance of a used 993 screen for good money. I've already bought the 964 rubber to fit into my 1983 SC. Cheers, JB
"Fast Beat The Feet!" Roughneck Brigade Brigadier #75 '83 U.S. 911 SC project custom car, mid-build '80 U.K. 930 Turbo, A2A2 Schwarz Black |
The best look IMO is to use the 993 window and seal, glue the window in. I've seen / heard of this being done, not sure if any other work is involved?
This is correct. I have a 993 screen and seal and it needs to be glued in. You will need a 993 rear view mirror as the glass comes w/ the mount bonded on. Any qualified window technician can do this. When my original glass got cracked, i actually had Safelite do the upgrade and i provided a new OEM seal. No issues with leaking or anything else.
Mat P 1988 911 Carrera |
With the 964 seal there's not sufficient space for both ...
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
Update on this topic.
The 993 screen I was offered was cracked so I've sourced a 964 screen and going that way. Cheers for the advice.
The 964 windshield and "Factory Seal" is the way to go for this upgrade.
RGruppe #180 So many cars.. so little time!! |
Does anyone have recommendations for shops in SoCal / San Diego that have successfully installed 964 windows (front or rear) and 964 seals in a G Body?
When my 1989* coupe emerges from paint, I'd love to lose the old seal / aluminum trim setup. ![]() *Late 1989 G bodies came with 964 windshield seals. Alas, my car missed the cutoff by ~74 cars.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
