-   -   Temperature Gauge Fluctuating (http://forums.pelicanparts.com/porsche-911-technical-forum/667997-temperature-gauge-fluctuating.html)
CT Mike 03-26-2012 06:28 PM
Once the engine is warm my temp gauge registers temperature but the needle bounces around, about 1/4 inch. It's never steady. Im assuming this isn't normal. Sound like the gauge or a sender? Thanks for the feedback.
timmy2 03-26-2012 07:30 PM
Loose connection on either end?
DRACO A5OG 03-26-2012 10:15 PM
Disconnect the negative side battery for safety.
Pull gauge, and clean/polish the connectors. If connector is loose tighten it.
+1 go to the sender/switch and clean/polish as well.
If this does not fix it then it may be a bad sender or gauge. Before buying a gauge, see if a neighbor Pelican can lend you his to test. An excuse to meet for Beer and talk 911 shop :D
