-   -   Swepco 201 - Only avail. mail order? (http://forums.pelicanparts.com/porsche-911-technical-forum/66807-swepco-201-only-avail-mail-order.html)
TedSlick 04-26-2002 02:29 PM
I was hoping to buy a gallon for use this weekend. Can it be bought off the shelf? I'm in so.Cal (San Diego) area. Any sources?
Otherwise, I suppose I'll place an order and do the waiting thing...http://www.pelicanparts.com/support/smileys/draai.gif
Where do you get yours'?
emcon5 04-26-2002 02:40 PM
If you can't find a store that carries it, call around to the local Porsche wrenches. A lot of them get it in bulk, like 30 gal barrels, and will be happy to sell you as much as you need, as long as you have something to put it in.
This is what I did last time I changed it.
Usual tranny fluid reminder: Make sure you are able to open the fill hole before you open the drain hole.
Tom
Formerly Steve Wilkinson 04-26-2002 04:10 PM
It's basically a lubricant used by diesel truck people who don't even know what a "Porsh" is. If you have any serious truck repair shops in your area--mine has an old Diamond Reo sign out front--check 'em out.
Stephan
TedSlick 04-26-2002 06:17 PM
Diesel trucks, huh?
Interesting. Wonder when it was first tried in the 915 trans.
Just someone's experiment?
TedSlick 04-28-2002 06:15 PM
I spoke with the so.Cal SWEPCO Rep...
says the only local source would be a Porsche shop here in town
-OR-
if I want to buy a case (6 gal.), I can get the industrial quantity price of $154 +tax, free shipping.
Need a gal. or two??? :D
tummi 04-28-2002 08:08 PM
Dude, since i'm on a rampage tonight (2nd ever post) i've done some research from this board on this stuff. I ended up putting it in my car and i was disappointed at first - didn't seem to fix any problems. I'm like i'll definitely need a rebuild. But after some driving (~100 miles) i could even get the car in 1st gear while rolling! (although at precise rpm). I don't have to nick 2nd before putting it in 1st at a stoplight if i don't want crunches. I don't want to act like this is a cure-all because it isn't. I'm also getting used to the gearbox because it's a relatively new car to me so that helps, too. But one thing on my box i've noticed is when putting it in third i used to have a whirring sound resonate up the stick from the gearbox. That has decreased dramatically. Also, downshifting to 2nd, if i don't get it right it may pop out of gear at slower speeds- that seams like a sync wear problem that i may just need to figure out how to drive better with. The swepco didn't seem to help there. If your old 915 doesn't shift like a new sports car, just think of it as a challenge. I know this doesn't answer your question of where to get it tomorrow, but look at it as an intermediate solution, not as a fixitrightawaythisweekend solution.
TedSlick 04-28-2002 09:12 PM
"whirrrr sound when shifting up to 3rd" ... Yes!
I have the exact same condition, like when pushing it quickly up to freeway speeds on an onramp. In fact, I described it as a "whirrr" when I mentioned it the first time I posted. Sounds like it's coming from the shifter itself (???)
Looking forward to trying this stuff...
tummi 04-28-2002 09:25 PM
dude - i'm glad someone else has this problem. I didn't know if it was just common enough that no one mentioned it or uncommon enough that no one mentioned it and i've searched the boards thoroughly. . Anyone else? It sounds like a high pitched metal whirring, a digital bird? Just don't try to shift it as fast as your '92 isuzu pickup.
speeder 04-28-2002 11:01 PM
As for the six-gallon price, you can probably get a Porsche shop to sell you one gallon for $25-30, (more than you need), Pelican sells for $34(?) one gallon. I have it in my needing-rebuild 915, people reporting huge improvements must have had empty trans previously, or castor oil or something. No miracles, but good oil I guess. :cool:
Wayne 962 04-28-2002 11:52 PM
It's only one day shipping to San Diego. Swepco called us the other day to make sure that we knew that we could also buy it in 55 gallon drums. I'm sure that's quite useful for us...
We're selling a lot of this stuff, and our customers seem to love it!
-Wayne
TedSlick 05-02-2002 04:00 PM
Found the Swepco 201 locally.
As a few guys mentioned (above), I have to bring my own 1 gal. container.
jkeyzer 07-16-2002 03:51 PM
Bringing back an old post...
Where in SD is this stuff available?
I forget if Inter Auto carries Swepco, but I bet Black Forest does... Anywhere open late?
nostatic 07-16-2002 04:22 PM
Originally posted by Wayne at Pelican Parts
-a bunch of work related stuff-
-Wayne
Wayne...GET BACK TO YOUR VACATION!
sheessh...you're worse than me (no real vacation in 5 years) :eek:
Wayne 962 07-16-2002 04:47 PM
Dude, I wrote that response in April...
-Wayne
ChrisL 07-16-2002 04:51 PM
Talk about having a premonition....
nostatic 07-16-2002 04:53 PM
yeah, but you're here responding to it so I stand by my admonition. :)
john_colasante 07-16-2002 04:55 PM
Dude, you're still checking the forum from vacation...
john_colasante 07-16-2002 04:56 PM
Nostatic dude, you're not one to talk. We should ban you until you find a 911...
nostatic 07-16-2002 04:57 PM
But then you'd only have BigB to kick around...and there's waaay too much testosterone in here to use on just one target.
jkeyzer 07-16-2002 05:10 PM
Dude, where do I get my swepco?
