thor's Avatar
1969 tachometer
hello ,
my tachometer has been totally rebuilt on my 1969 2.0 .
engine is running well (new) but nevertheless the tacho does not answer.
it seems there is a problem between the CDS and the tacho (black purple wire)
i 've checked the wires and it is ok.
then there is still the small grey component (SCR switch ) between CDS and tacho. Can I directly take the CDS wire to link it to my tachometer and then bypass this component ?
is there a risk ?
thanks a lot
Old 04-06-2012, 01:04 AM
304065's Avatar
Thor,
What model is your 69? I assume an E or S with factory CDI? Let's start with what you have, a photo would help, then we can get around to diagnosing the problem.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-06-2012, 06:45 AM
thor's Avatar
Hello
It is a 69 e , i rebuilt my engine .
Tachometer was running well before and it is the original one.
May be the fact the car did not run during 5years it creates a defect .
Can i connect directly the tacho without problem just to see if it works like that . If yes it means intermediate unit is not working ....
The cdi is working well as the engine is well running
Jerome
Old 04-06-2012, 01:13 PM
thor's Avatar
Any help please
Old 04-07-2012, 07:59 AM
thor's Avatar
Is it normal to have a black purple wire connected to the mfi transducer
See my picture on the following link
electric question : 2.0 E engine compartment
Old 04-09-2012, 12:24 AM
thor's Avatar
I mean before rebuilding my engine the tachometer was ok .
As i let the car few years in the garage before all was restored , may be time , humidity ....
Before re sending the tachometer to be rebuilt to bypass intermediate unit , i would like to be sure it is intermediate unit the problem. ....
Old 04-09-2012, 01:33 AM
thor's Avatar
I've received my tach modified to bypass the intermediate unit.
i've wired the bk/pu wire to the distributor and at last it works ...
I let the intermediate unit in place to keep original but it was this unit which was faulty....
thanks all for your help
Old 07-01-2012, 05:34 AM
I wish that you had posted initially that your tach had been modified to bypass the "intermediate unit." I believe that the " intermediate unit" you refer to is in fact the ballast resistor mounted on engine electrical panel left rear. Silver cylinder bosch 0 227 990 001. Only used 69/70/71 to use older tachs with cdi ignition. With a newer or "modified" tach in order to make it work it is only necessary to remove the ballast resistor and then jumper wire from the distributor to the black/purple wire that was attached to the ballast resistor at terminal C. Your tach should then work. I just got through doing this on my 70.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 07-01-2012, 07:40 AM
thor's Avatar
You are right.
I let this silver part on the panel but i ve wired the black purple to the distributor.
Jerome
Old 07-01-2012, 07:51 AM
