Senior Member
How much oil pressure should i get when cranking? (after rebuild)
Engine is back in, auxillaries have been fitted, but since I have a problem with my other weber the car is still not running.
But I am asking how much oil pressure should the oil pressure gauge show when cranking. I need to know before I give the car a spark. I cranked..well quite a lot, and the gauge just slightly moved when I cranked the engine. What should I see? Ah, you ever noticed how hot the ground wire gets at the front compartment. Well at least it did get hot with my old ground wire. I replaced it with a new wire and now it won't get hot at all. If yours gets hot, replace it. 911@b-faster.com |
You do not have permissi
Sorry I don't know the answer to your question Zenlander, wish I could. I've heard that using white lithium assembly lube can really gum up an engine later on. Mabye the head pressure limiting valve is stuck open/closed or the gauge is bad. You could pull the sender out and use a screw-in type.
Good tip with the oil-prime and ground tips, I'm gonna go check on mine. I thought I'd add that I've heard of some systems that have the ignition coil that grounds through an oil pressure switch. That way the engine doesnt go past low cranking rpm until the pressure is up. Most of the wear is at startup. |
Author of "101 Projects"
The oil pressure light should go out after about a minute of cranking. If it doesn't, then don't start the engine.
You can then start cracking open things like valve covers to see if you're getting oil pressure while cranking... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
The thing is that i don't have oil pressure light. I don't know which wire in dash goes to the lamp.
If you know which wire it is in -72T please tell me ![]() 911@b-faster.com |
You're cranking with the sparkplugs out, right? Silly to do it with the plugs in, if what you're trying to do is establish some oil pressure before first start. You shouldn't see much in any case; if the needle moves to show positive pressure, that's fine. Oil pressure is a function of engine speed, and if you're only turning the crank at whatever speed you can achieve with the starter motor, the pressure will be very slight--even slighter with the plugs in place.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
