cam timing
Its time to time the cams on my 84 Carrera. The modifications Ive done are a 3.4 Mahle cyl set,twin plug conversion and custom chip. Should I set the cam timing to factory specs?
Old 03-29-2012, 02:01 PM
you should ask this question on the engine rebuild forum. You will probably get more answers.
Old 03-29-2012, 05:34 PM
I would rather be driving
jpnovak's Avatar
If you have the stock cams then time them at the factory spec. If you swapped cam grinds then you should use the spec that came with the new cams.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 03-29-2012, 05:40 PM
Thanks! My cams are factory stock so I will time them to factory specs!
Old 03-29-2012, 06:22 PM
T77911S's Avatar
all that work and stock cams? why?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 03-30-2012, 06:42 AM
