-   -   Adjusting the idle on a 3.6 (http://forums.pelicanparts.com/porsche-911-technical-forum/668579-adjusting-idle-3-6-a.html)
Joeaksa 03-29-2012 03:37 PM
Tried searching and no luck.
Anyone know how to adjust the idle on a 3.6 964 engine? Its at times going up to 1200 at idle and would like to bring it down a bit.
Thx, Joe
budge96 03-29-2012 05:25 PM
either you have a minor manifold leak or need a new idle control switch (unit),don't believe there's a manual adjustment
midnight911 03-29-2012 06:24 PM
i had the throttle wire routed in a way that there was too much friction in the wire which prevented the throttle to close completely.
Joeaksa 03-29-2012 07:43 PM
Thanks and will check all of the above!
What should the engine idle at normally? Am guessing 900 rpm's or so?
Joe
midnight911 03-29-2012 09:16 PM
mine is 95 993 3.6 with custom chip. it idles a little high at 900 rpm or so.
don't know where it should be but i trust the guy who did the chip.
Joeaksa 04-02-2012 02:46 PM
Thanks for the info everyone!
Joe A
