-   -   Fuchs are getting old- Check them for cracks..... (http://forums.pelicanparts.com/porsche-911-technical-forum/668815-fuchs-getting-old-check-them-cracks.html)
Plavan 03-30-2012 05:51 PM
I was bolting this a 15x8 Fuch up on my race car and look what I found.....
These wheels have only been on the track maybe 4 weekends (I have two sets). These were not even my curb hopping set. Be safe and check regularly.
http://forums.pelicanparts.com/uploa...1333155070.jpg
ratpiper71T 03-30-2012 07:58 PM
Wow, good catch. Out of curiosity, have these been refinished in anyway?
Plavan 03-30-2012 08:12 PM
When I recieved them, they were just old- I bead-blasted them for the correct RSR texture then just painted them. (RSR Economy Finish). The other 3 I have are fine- I'm just going to check them everytime I touch them.
nesslar 03-31-2012 01:38 AM
Are those real "forged" Fuchs"? They look cast.....
Plavan 03-31-2012 04:30 AM
Yep- real Fuchs. I would not race on fakes.
Bead blasting them gives them the RSR texture you see.
KTL 03-31-2012 05:55 AM
Its weird that the crack starts from the center bore and moves inward. Intuitively, i'd think it would start at the lug hole and move outward?
pksystems 03-31-2012 06:11 AM
I picked up some used fikse centers, and found similar cracks in the spokes of one.
cmpski 03-31-2012 07:50 AM
Can that be repaired?
nesslar 03-31-2012 09:15 AM
I see. I've not seen such a close-up of the RSR finish. And wow...good eye for catching that!
Arne2 03-31-2012 09:28 AM
Looking at this with 20+ years experience in tire and wheels service (prior career), to me it looks like stress from the hold-down cone of an old Coats tire changer. Probably not recent stress, either. More likely from back in the '70s & '80s.
Wayne 962 03-31-2012 12:44 PM
I've heard and seen cracks like these but I can't recall ever hearing about a Fuchs actually failing? Anyone have pics / info?
safe 03-31-2012 02:54 PM
Only if your going to use them for peaceful Sunday cruises.
mpeastend 03-31-2012 10:39 PM
There was the case of Matteo's Lindsays that came close to failure on a track day outing in England. He was cornering and heard noises...turned out the rim center was so badly cracked, the entire center was flexing and the rim was rubbing on the calipers. He was really lucky it didn't fail at that moment.
It started some discussion on the prior life/load cycles that the donor 6x16 wheels had before being cut out and welded up by Lindsay racing. I have a set for my IROC clone & check them often but would like to get a modern set to use on the track like the Zuffenhaus ones.
I'd include a link and/or pics he posted but any search for Matteo's thread came up empty. Don't know why. I remember he posted pics of them...pretty badly cracked. Lucky, he was through enough with that car!
haycait911 03-31-2012 11:19 PM
is it possible that was caused by trying to hammer in a cap crooked, or wrong caps?
Plavan 04-01-2012 07:22 AM
Unlikely, plus We don't run with caps.
Plavan 04-01-2012 07:27 AM
I will not try and repair it. The wheel will now become a Wall Clock, some type of Art, or a cool hose reel.
KTL 04-02-2012 07:26 AM
cstreit had some crack like this a number of years ago.
http://forums.pelicanparts.com/porsche-911-technical-forum/76027-fuchs-wheels-cracking.html
Now that I think about it, it makes sense to start at the center. The wheels are hub-centric and the center bore is what secures/supports the wheel to the axle. The lugs of course hold it tight. So the lugs are like secondary support?
Jack Olsen 04-02-2012 07:47 AM
A Fuchs wheel has a finite lifespan, and that lifespan is measured in the amount it has been forced to flex more than chronology.
Every time the metal is stressed adds to the cumulative effect.
Craig T 04-02-2012 07:47 AM
Chad, during the POC Spring Mountain event in 2010 a time trialer had a catastrophic Fuch failure in Turn 2 (high 3rd gear turn). The wheel broke completely off at the spokes. The left over star made a nasty cut in the track. That event touched off some controversy with the tech shop and a closer exam of the Fuchs on POC cars. I believe at least one other cracked Fuch was found.
hcoles 04-02-2012 08:07 AM
I like this thought on the root cause, something to the watch when getting tires changed, e.g. no reason to hammer the wing nut pushing the cone, a firm push by hand should hold it.
silver_911 04-02-2012 08:11 AM
I have a similar crack (~1 inch), starting at one spoke close to the outside of the wheel.
7x15 forged original Fuchs, fully polished. Have them since ~8 years and discovered it after a 600mls tour through the alps.
jens
Arne2 04-02-2012 08:18 AM
Those old tire changers broke the beads by applying a bunch of force from the side, while the wheel was retained by the cone through the center hole. The stress was all concentrated on the edge of the center, exactly where this wheel is cracked. Modern changers do not apply this force against the center.
Flieger 04-02-2012 11:18 AM
Not all are hub-centric. And Harvey Weidmann said that the hub centric bit gets dinged up quickly anyways after a few removals and re-installations so they end up being lug-centric.
Flieger 04-02-2012 11:19 AM
This. Aluminum fatigue fails after cyclical loading no matter how little stress it sees (unless it is zero). It just takes longer to fail with less stress.
KTL 04-02-2012 11:37 AM
I'd be willing to bet that the lug areas are more dinged up than the hub area. The studs dish out more abuse on the lug holes than the hub gets from the wheel carrier.
The tire changer theory is a very good one! I'm not saying the metal doesn't have a finite life. I'm just agreeing that those older tire machines are brutes and the leverage they can place on the wheel is an incredible amount of force.
Flieger 04-02-2012 11:43 AM
Yeah, but the ball seat area seems pretty good.
