rubber trim question
Hello- I had to pull away the rubber trim to take out the torsion bar body plug. Now I would like to put it all back-is there an easy way to reseat the trim in the upper and lower channels? Thanks
winter
Remove the entire piece and then slide it all on in one go. Sometimes you'll need to lubricate it to get it to go back easily. I've used soapy water, some have used WD-40, you may not need either.
Good luck. |
I read once to do upper or lower first all the way across and then work the remaining side on....do a search
Thank you!
+1 on the slide it in method, just make sure it's clean (I don't lubricate but it couldn't hurt).
Chuck.H '89 TurboLookTarga, 332k miles |
I slid mine in too. To lube, I used windex.
