-   -   The engine is back in! (http://forums.pelicanparts.com/porsche-911-technical-forum/66897-engine-back.html)
Jadams1 04-27-2002 03:56 PM
Today was the day the engine went back in but I still have a few more things to hookup. I'm about 2 hours away from firing it up with the exception of the distributor rotor. When the engine was out I tried to remove the rotor and it wouldn't budge. So I gave it a little more force and removed it in two pieces. I called around and couldn't locate one locally. You guys in California are really lucky being close to the supply houses. So I'm a week away from starting it up due to a broken rotor.
The reason I took the engine out was to replace all the lower dilivar head studs with steel ones. I opted not to do a top end rebuild based on the mileage on the car and after inspecting everything. I also did the chain tensioner upgrade too.
Thanks for all the advice and help along the way. It's a great feeling to know I can always get help from this board.
John
http://www.pelicanparts.com/ultimate... install L.jpg http://www.pelicanparts.com/ultimate...ine in car.jpg
bell 04-28-2002 06:01 AM
just in time for spring:D
i like your polished fan, i'm thinking of doing the same with mine.
lets see pic of it spinning when you get it runningSmileWavy
