Getting ready for first mods
M&K 1 in / 2 out GT3 muffler, ceramic coated
M&K Euro pre-muffler Older Momo steering wheel and hub, will be doing the center cap horn button mod SW chip turbo tie rods 74 Oil Pressure/Oil Temp gauge with senders Magnecor ignition wires Euro bumpers Veronica's engine is also being dropped to repair a seal leak. Kevin Wheeler of KMW Motorsports in Boca Raton will be doing most of the work and I'll try to do some of the simpler things...still learning! http://img687.imageshack.us/img687/6148/img0223or.jpg http://img813.imageshack.us/img813/2091/img0224ol.jpg http://img845.imageshack.us/img845/5848/img0225ea.jpg http://img252.imageshack.us/img252/8572/img0228ed.jpg |
Well,that's a good start !!!
I have the Turbo tie rods and the MK pre muffler on my car ... good choices ! Oh yeah,Magnecores as well ... Veronica will be happy :) Cheers ! Phil |
Nice. I still have a box of stuff to do from my first Pelican order after I got my current 911. Every order after that, more gets added to the to-do box.
This is what they call the "slippery slope." |
post lots of pics after install :)
a video of the exhaust once its in would be nice too |
Awesome!
you are going to go down the slippery slope. you really should stop right there. ...and you can avoid going down by giving me that euro bumperettes! ;-)
keep us posted! |
The bumperettes are on our host's website... |
Done
Kevin at KMW in Boca Raton did a great job. I didn't put the Euro bumper guards on because of fit and paint but everything else went well.
The front seal leak is fixed, oil change done, turbo tie rods on and car aligned, Steve Wong chip in, Magnecor wires in, older oilpressure/ oil temp gauge in, the steering wheel and horn button mod is on, and the M&K cat bypass and GT3 1-in, 2-out muffler are installed. The low end is stronger, acceleration is very smooth, and the muffler sounds great (and loud). A couple of photos and a short video of the exhaust. http://i291.photobucket.com/albums/l.../IMG_0272s.jpg http://i291.photobucket.com/albums/l.../IMG_0271s.jpg The video |
Any drone/resonance with the muffler?
Tomorrow, I'm going to take it for a longer ride and I'll let you know; my guess is there will be some, and the drive will give me a chance to find the sweet spot where it is minimized. |
911 mods
Met you at KMW before the work was done on your car.I saw the car again two days later.It looked great and sounded awesome.As usual another great job by Kevin and his crew at KMW.Congrats on a really nice car! John Szabo. P.S. I was in the Viper green early Ford Bronco
John and Elias, it was nice meeting you guys at Kevin's shop. Hopefully, we'll all see each other again.
I like your horn button ;)
I would be real curious if those rear bumperettes work for you ...and if so where you found them - I have a set i was hoping to put on....but there is a lower valance issue that is causing me a stop work order.....seems the valance on the SC and earlier is forward about 1/2 an inch from the 86' which means the rubber hits and there is a 1/2 inch gap still!!
DOH !! nice pile - post pics! |
LEFT- Pelican Parts - Product Information: 911-505-341-00-M136 RIGHT- Pelican Parts - Product Information: 911-505-342-00-M136 |
http://forums.pelicanparts.com/uploa...1334661879.jpg |
BTW, beautiful color on your car...it's got a green tint to it...what is it? |
Thank you. The color is Oak Green Metallic. People mistake it for black all the time, until they get close. It used to be Ferry's favorite color.
There are 4 holes that need the plugs popped in. I can't remember the size you need, but they were like $4 at Lowe's. The plugs are very low profile, so after I painted them with touch up paint I had laying around, you can barely see them. Plus, if you ever wanted to go back, you can pop them out and reinstall the bumperettes. |
So, the steps I followed: 1. Under car, remove rear valance. 2. Behind car, remove license plate lights from bumperettes. 3. Under car, pull license plate light wires into the rear bumper. 4. Under car, unbolt bumperettes from inside rear bumper. 5. Behind car, pull bumperettes off (may require light tapping on studs in bumper). 6. Behind car, drill holes in bumper for Lite n' Bolts. 7. Under car, wire and mount Lite n' Bolts. 8. Behind car, pop caps into the holes left behind by bumperettes. 9. Under car, reinstall rear valance. 10. After about a month, the rubber impact strips loosened and sat straight back. As a result, I got some epoxy and stuck them back on, they've been there for 1.5 years without coming back off. Eventually I plan to get rid of the Lite n' Bolts. I'd like to get license plate light holders from a BMW 2002 (our host sells them) and mount them onto the bumper. The Lite n' Bolts illuminate the license plate fine, but they are blue LED's and it just doesn't look right on a vintage car. |
Looks great! One question did you mod or remove the valance panel?
| All times are GMT -8. The time now is 12:13 PM. |
