-   -   Need help ID'ing a part (http://forums.pelicanparts.com/porsche-911-technical-forum/669331-need-help-iding-part.html)
Kemo 04-02-2012 02:05 PM
What is the name of the thingy in the door jam that actuates the inside dome lights? You know, when you open the door and the lights come on...
mines no worky and Id like to replace with a new one but for the life of me cant figure out what to call it.
thanks!
Dublinoh 04-02-2012 02:21 PM
dome light switch?
Nope door light switch link:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911M&section=ELswch&page=3&bookma rk=15&part_number=928-613-147-00-M100
There is also a door light switch washer, and rubber seal
Kemo 04-02-2012 02:56 PM
thanks for the lead...
looks like I need 964-613-601-00-M260 for my 78' SC.
along with the rubber cap 901-615-616-20-M260. I think Ill get 2 of these :)
thanks again
bfunke 04-02-2012 06:45 PM
Before you buy a new switch, remove the rubber cover and unscrew the switch and clean it with electrical contact cleaner. Spray it on and push the button repeatedly. Usually that removes the corrosion. Apply a small dap of grease to the contact and reinstall. If you rubber covers are cracked or brittle replace them. If you decided to replace the switch be careful to secure the wire and not let it slide into the hole as that will be a royal pain to retrieve. Best luck.
Bryan
