-   -   Gauges question (http://forums.pelicanparts.com/porsche-911-technical-forum/669692-gauges-question.html)
baruch mor 04-04-2012 11:21 AM
Gauges question
Can I modify the light coming from the gauges to white LEDs ?
If not what is the best choice for a set of newer gauges for my 76 targa g50 3.2?
Porchcar guy 04-04-2012 11:48 AM
There are a number of good threads on this issue...the search function is your friend and will answer better than I could ...check it out
cain 04-04-2012 12:32 PM
Yes, you can, plug and play, I have bought mine from Etarga forum member here.
Just plug em in and your done, no issues, from my experience!
An amazing improvement over stock
80-911SC 04-04-2012 01:22 PM
+1 for etarga he sells full kits that are correct ... I do not have one but it gets rave reviews your search function will find quite a bit on the subject .. you can find them other place and maybe cobble them up but his a tried and true .. one call does it all he has done the leg work to find and make what will work not what might work and that is a big plus ....
.. just remember not to change out the alternator bulb with an LED .. if you do it will not allow your alt to charge your battery ....
TonyGO 04-04-2012 04:58 PM
Leds
Just did my 79 911sc now i can see my gauges at night ,real easy plug play,got mine online at www.autolumination.com Tail Light Brake Light Turn Signal LED Bulbs go for it youll love it TonyG.
RSTarga 04-04-2012 05:51 PM
See above thread ultimate led...They are a direct plug in and work great.
mppickett 04-06-2012 04:37 PM
Another +1 for the etarga LEDs. I bought a set for my '82 and really like them. Easy, direct replacement.
DRACO A5OG 04-06-2012 07:42 PM
+1 eTarga, pm him:
http://img.photobucket.com/albums/v5...214_175724.jpg
