Glue for around door
I want to install the rubber that goes all the way around the door opening. What glue should I use.
I am tired of using that ugly yellow 3m stuff that gets all over everything. This is for a SWB.
Thanks in Advance
Old 07-30-2012, 06:27 PM
jsut use the spray stuff. the panel holds it down so you don't need anything super strong.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-30-2012, 06:38 PM
Porsche fanatic
jager911's Avatar
3M Rubber and Vinyl Adhesive in a spray can is what I used, you may need to spray closer to avoid it making a mess. Use Masking tape to protect surrounding areas. It cleans up with alcohol.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 07-30-2012, 08:06 PM
Old 07-30-2012, 08:07 PM
Cooper911SC's Avatar
Use 3M Weather Strip Adhesive. They make Black and Yellow...
Be sure to clean and prep. the jamb.
Follow the instructions on the Adhesive. Make sure to coat both the jamb and the seal. Allow them to flash off and just skin over before bonding them.
My .02
Cooper
Old 07-30-2012, 08:40 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
+1
Originally Posted by cooper911sc View Post
use 3m weather strip adhesive. They make black and yellow...
Be sure to clean and prep. The jamb.
Follow the instructions on the adhesive. Make sure to coat both the jamb and the seal. Allow them to flash off and just skin over before bonding them.
My .02
cooper
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 07-30-2012, 11:51 PM
